Filling Holes in Veneer
Howard in Bethesda
>I have been laying up burl veneer that has a lot of small holes and individually filling each hole with Famowood wood filler with good results.
I have some more burl with numerous holes and was wondering if instead of filling each hole individually I could use grain filler in the conventional manor over the entire piece of burl. I would then sand the grain filler off the surface. This appears to be a much faster way of filling the holes?
Thanks
Howard
Re: Filling Holes in Veneer
>Ever thought of using colored epoxy?
Tom
Depends
>Wood filler is a good way to fill grain, but you need to tint it to be slightly darker than your deepest-colored adjacent grain. If you don't tint the filler through and through, you will be grain painting the individual repairs later.
Ellis Walentine, Host
Lee Grindinger
Well, I have a solution too
Lee Grindinger
>Burls are often in need of filler and what worked for me was to make a paste of liquid hide glue and sawdust of the same species as the burl. It dries a bit slower than solvent based fillers like Famowood but honestly, I got tired of throwing the expensive fillers away. The match using sawdust and hide glue was perfect and shrinkage was minimal since the patch was only a veneer's thickness.
Lee
