Re: OT: Firefox3 SLOW!!!!!
Bill Hammond, Oregon Coast
>My internet computer is not new nor is it fast but FF3 runs faster than the previous versions.
Try disabling some of the Add-On Extensions and setting the theme to the generic one. Also, is your Java version current? Try dumping all the cache and deleting all the temp files in your temp dir.
You may want to DL the installer for Firefox again, uninstall and then reinstall. Just in case something was messed up with the original install. You most likly only need to save your bookmark.html file from the original install. It's located under Documents and settings / user name / Application Data / Mozilla / Firefox / Profiles / and whatever profile that is yours probably something.default. Copy the file somewhere safe. After the uninstall of Firefox delete the Program files directory and the one in documents and settings. (or just rename them so you can go back if necessary) Then reinstall and see if it runs ok. Then copy in your bookmarks.html and check again. You may even wish to download the current Java and then uninstall all versions of it and start over with the new one.
Hope this helps and doesn't just make things worse.
Bill
