Window question
Window question
Window question
jeff
>Hi all
I have been trying to resolve a problem.
I'm renovating a bathroom.
I need to find some super-insulated windows.
They will be installed in a shower, so I need fiberglass or vinyl on the inside.
An awning style for high placement on the wall.
My research hasn't turned up a good supplier here in Vermont.
I was a little surprised to have this much trouble.
Hopefully, someone here has some good advice.
Jeff
Re: Window question
Re: Window question
mdclor
>Jeff, if you can't find what you want, you might consider glass blocks.
HTH,
Merle
Re: Window question
Re: Window question
>Try Certainteed. I installed a couple 20x36 vinyl awnings in a small remodel in my house; not a bathroom. They're well made and easy to install. I'd use them again.
Clint
Re: Window question
Try Great Lakes *LINK*
Lee Schierer - McKean, PA
>We replaced all the windows in our house including the bathroom window with vinyl windows made by Great Lakes. The Bathroom window was an awning type window and is 100% vinyl inside and out with a life time warranty. I don't know if they have a distributor in your area.
Lee
Great Lakes Windows
Re: Window question
Re: Window question
>Good suggestion; I replaced a rotted wooden double hung with glass block in a bath remodel. The blocks are set into an aluminum grid with a weather strip looking caulk. It was much easier than setting with mortar. Weathertight and stays good looking.
Clint
Re: Window question
Re: Window question
Bill Hammond, Oregon Coast
>I have put Vinyl windows into showers before. Up high it's not a real problem but if the water can hit it then they get soapy and scummy and all those little places that vinyl windows have seem to get filled up and are a real pain to clean, and then they start to smell.
In retrospect I would have done better with block set in rubber things on the bottom and a vinyl slider or casement on top. This does however shout BATHROOM from outside and distorts the look of the house. You want to be very careful about not using any caulking that will mold and to slope the flat surfaces to drain back to the shower.
If you use the block that gives the distorted view through them it's a very interesting view from outside yet modesty is still retained.
Bill
Re: Window question
Re: Window question
Chrispy
>I put a Vinyl window from Home Depot in our bathroom during a remodel. The window is on the end facing the shower but is 5ft from the shower. It's been there some 4 years with absolutely no problems with only a monthly cursory wipe down, with about once a year a thorough clean. ie remove the fly screen and wash all over with a clorox solution, The window is:
American Cratsman 1500 (I think) series, mid range. Regards
Re: Window question
Re: Window question
Fred Davis
>Jeff ,
Bathroom windows are typically glazed with obscure glass, in most jurisdictions and all of the west coast it is required.
Do yourself a favor and use a good grade of Aluminum window which will never rust or rot or warp, and specify anodized rather then mill finish.
Unless you live in the northen climes of the country double pane is sufficent.
Fibreglass and Vinyy are awaste of your money.
FredD
FredD
Re: Window question
Re: Window question
Fred Davis
>that would be vinyl, ;-))
FredD
