I disagree completely
Michael Dresdner
>I'm sorry, Rob, but I don't agree with you at all on this one.
There is no difference in the way gel polyurethane and liquid polyurethane adhere. In fact, there is almost no difference at all between the two except for the fact that the gel does not drip so much, making it a bit easier to handle. In many cases, depending on the company involved, the solids content of the gel and liquid are identical, as are the resins used. Bear in mind that most gels are thixotropic, or at least pseudoplastic, so their viscosity at rest does not affect how they address the wood in terms of adhesion, wetting, or even absorption.
Either way, you will build a finish much faster using either liquid polyurethane right out of the can, or gel right out of the can, than you will if you buy wipe on poly, which usually has less resin, or if you reduce liquid polyurethane, which does nothing but make you buy paint thinner.
Adding thinner to any oil based material does not change it, since the thinners you are adding are diluents, not solvents. In other words, the molecular size and weight does not change when you add paint thinner, and that is almost totally what controls how far the resin will be absorbed by the wood.
