Shop update lots o pics
Ned Bulken
>Ellis, thanks for the FAQ on posting multiple photos... here goes:
I've been busy the past few weeks getting things buttoned up at my new shop. Here's a few recent shots:
That's one of several loads of stuff being unloaded. I really need to clear the 'driveway'. Good thing I'm an ex trucker and know how to back around obstacles.
rear of the shop finally closed in. I still have to put on the board and batten siding, as well as another couple of rolls of tyvek, but all in all, it is shedding water and keeping the insides dry.
there's the new lumber rack I decided to build. Predicably it has already gathered a mess up there:
I also have brought my benches up from storage:
the 'rear' bench is 41" tall, which is how I had both of them in my old shop I shared with my Mentor. I think I'm going to have to cut it down to match the other bench, which is at 35 3/4, or just under tablesaw height. I won't be using them for outfeed purposes, but if I have them clear(yeah, right!), I can still cut sheet goods without rearranging the shop too much.
a friend on familywoodworking called this 'working late'
There's my tall bench with my charging station and current power center... I'm still living off of an extension cord until I can find the money in the budget to get a box and so forth installed. Even doing it myself right now just won't work, materials costs being what they are.
Doors!
getting crowded in there
and for all you spinny types:
I also brought up my bench grinder, but that hasn't found a home yet, and I still need to buy new wheels for it.
Re: Shop update lots o pics
I'm prbably out of place here...
Eddie Pacheco: San Jose, Ca,
>And Ned, I certainly don't mean any disrespect. Typically metal roofing is installed over a plywood and tar paper substrate with fasteners spaced evenly per the mfgr's. and local specs. If your shop, as is roofed now, (based on 1st and 10th pictures)gets any severe wind the metal will start fluttering and may fail at the fastener areas. The force will be spread over the length and width of the roofing panels and it won't take a super strong wind to tear that metal roofing off. Please take a look at the installation specs for the roofing material you have and make changes if you need to, so as to better protect your tools.
I wish I had space like you to build a separate shop.
>Hello Ned,
Man, do I envy you the room. I'd love to start from scratch, rather than work within constraints which fate provided. Looks like you will be happy forever. I hope so.
George
Re: not at all.
Ned Bulken
>I had some sheathing up there, but it had warped after being exposed last winter/spring. so I took it down If it blows off, I'll just have to hire the neighbor again to replace it. it is screwed down to crosspieces every 6 to 8 inches, so I don't expect it to fail. Snow load is more important around here, and I expect it to more than hold up to that. I'm also planning on insulating and then putting some sheathing between the trusses on the inside, just one of those 'round tuit' things.
Ned Bulken
>George, I'm already feeling like I don't have room to turn around in there... once I add three more largish tools I'll really be space challenged. I'm definitely putting everything I can on mobile bases though. My TS came with the herculift, but I'll be getting at least one more mobile base when I pick up a jointer.
Galen V
>You are lucky to have a stand alone shop. Great.
Mine is confined to basement corner of rented townhome so I can only do so much. Well now it is half the basement till the landlord inspects.
Looks like yours is filling up fast.
I see what looks like two rough openings with headers on the wall with the lathe.
Is this were you have your future planned addition so you have passage to second room? Thinking ahead!
Hope you don't mind…
Rod Peterson -- Ormond Beach
>I took the liberty of capturing the pics and text and transforming it into a gen-u-wine WoodCentral Shop Tour.
Sometime when you have the inclination, you may want to send me some better, bigger pictures, and refine/expand the text part, too, if you want. Particularly when you get the heavy arn moved in.
Rod
Editor, ShopTours.org
Ned Bulken
>Man door and one of two windows... have to build the door, but I've got the window, just haven't installed it. I won't be expanding this shop, unless I tie it into the house.
Re: Hope you don't mind�
Ned Bulken
>I'm flattered, and I've got a whole bunch of verbage on my blog about the build, I'll condense it and send you some more photos when I get things a bit more completed. In the meantime, for those so inclined, there's the link to the blog below.
>Great. I'll probably cherry pick some stuff myself to massage it. As it stands, though, I'd like to leave the build pretty much as is, but concentrate on shop contents as your development progresses.
Nice shop.
Rod
>I like the general layout.
Like Eddie, I'd prefer sheathing under the metal roof. Around here, we generally have OSB, tar paper (or house wrap), the 1 x 4 stringers and then the metal roofing.
I presume you are going to put in wiring and lighting as time allows.
Are you going to have the "attic" area for storage? You've certainly got a lot of vertical space up there :).
Ned Bulken
>Eventually I am planning on getting up to the loft area for 'long term' storage, things like stickered lumber, christmas trees etc... it is 11' up in the air (or close enough), the side walls are 10' and there's 15' to the peak. I'm also planning on hanging some lightweight storage racks around the bottom side of the loft... for storage bins which are currently taking up one corner of the shop. That'll free up some badly needed floorspace.
the sheathing issue is what it is, and I've just got to press on with what I've got and hope for the best.
Wiring and lighting etc... will be coming as the budget allows later this fall, as will insulation and some sort of wall treatment inside and out. Inside i'm leaning towards plywood once I have the insulation in, and outside, board and batten is what the LOML and I have agreed on.
There are also two windows and another door to go in. I may wait on the door until spring, though. We'll see how things go this fall.
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Ned, I didn't catch in my quick review of this where you are, but I would just like to inform you of a product that I would try to use for energy saving whenever you are using OSB. Ask around or do a search for Solar Board. It is just osb with foil on one face. That small difference can make a huge difference in energy savings over the years, not to mention comfort level. It would have been good for your outside walls.
However if you are thinking of using osb for the inside walls. You could use it with the foil out still.
it is a simple mater of physics. Dark objects absorb light, convert to heat and radiate it away. Light bodies reflect it, but won't radiate it when hot. Highly reflective like foil or mirror surfaces are even better at not radiating. It is great for roof decking, especially when using dark shingles, in that the heat absorbed from the Sun has to go back out the top.
Ned Bulken
>I'll look around for it. I'm in central NY, but things inside are far from done, and it is a work in progress.
Under the flooring, I have a layer of silver plastic roll insulation, i don't recall the product name off the top of my head, but they sell it in 16 and 24" widths, and I'm planning on adding a layer of that up at the eaves. I'll check on the foil wrapped osb though.
It can be done...
John in NM
>Though I'm not an expert on metal roofing, and ours was a type designed to go over sheathing, there are a number of products designed to be screwed directly to the purlins with no sheathing. IIRC, there is an end trim piece, like a facia board that covers the edges and would probably solve the wind problem.
Don Orr
>Lookin' good there Ned. Nice to see major progress. I'll bet it feels good to move things in and be able to work there. Keep plugging along and you'll be done before you know it.
Enjoy !
posting multiple pics
McKay Sleight
>So how does one post multiple pics? Do you need a web page to do so or what? Thanks ahead of time. (nice addition of shop space.)
Re: posting multiple pics *LINK*
Ned Bulken
>First you need to have your photos on a hosting site, I happen to use Photobucket, but Google's Picasa works, as does Flickr, all of which let you upload imaged, and then link to them via a direct address to the image.
Ellis' Messageboard FAQ on this describes the process for here:
multiple images FAQ
Ned Bulken
>Thanks, I"m still working on it, but it's been a long time coming, and I'm so looking forward to getting home from work, and time allowing, heading back to the shop.
Bart Leetch
>See I told you not to get any older ..... you forgot the insulation & siding &&&&&&& there is just to much left to do & winter is coming.
SO GET BUSY!!!!!
Re: you buying?
Ned Bulken
