?? on wood floor color changes over time
Tim Greif - West of Chicago
>5-6 years ago, we had our oak floors completely redone since the finish had worn away in high traffic spots (wainted way too long to screen and finish) and we wanted to lighten up the color. We had the old dark stain sanded away and finished with a slightly tinted golden oak and topped with four coats of Bona Mega.
We've always had a rug at each of the outside entry doors onto the floor, of which there are three. One sees alot of sunlight (west exposure) and the others do not. The floor has lightened enough on the sunny exposure that there's a noticeable difference where the rug lays. The other rug locations show no color variation from adjacent floor area. Is this just normal sun bleaching of the wood stain? The Bona stuff is waterborn so I assume it's not changing color. Any way to restore this? Or just keep a rug there all the time? LOML always wants a rug at the entry - claims it saves the floor from further scratches and occassional rain damage.
Re: ?? on wood floor color changes over time
Andy Halterman: What's this rain stuff?
>Standard bleaching by the sun is what you got. Even the finishes with UV blockers will still allow this to happen, it's just a matter of how much. The rug solution sounds like a very good inexpensive solution to this dilemma. You could try and do a spot repair but I'd be it would show more than you'd like. Mega will amber slightly over time but no where near what an oil based poly will do.
If you'd like, I can lie and type up a really rosy response instead. :-)
Andy Halterman
First measurable rain in almost two months in drought stricken Hendersonville, NC�
>Andy has it right. Sunlight is the enemy here, and it's doing its thing. If you have four coats of a finish already on there, I would not recommend refinishing unless there is no other choice. Here, I suspect that your rug solution would be the least effort and cost.
If you really want to try to repair this situation, it's a crapshoot. You can try using water-based dye stains, but frankly, all stains fall somewhere on the continuum of UV susceptibility.
One other possible suggestion would be to take the rug away. The floor will change to the color of the surrounding floor at some point.
Not much help,
Ellis Walentine, Host
Thanks Andy and Ellis - pretty much ....
>Thanks Andy and Ellis - pretty much what I expected. I really like the durability of the Mega finish. Only reason for asking was we're probably going to have the floors screened and another maintenance coat applied sometime this year. I sorta doubted there was anything that could be done but figured I'd ask before we did that. I was hoping Andy would chime in since if anybody had a cure, it'd be him.
Thanks again. I'll be using that rug.
A cosmetic possibility
>If you are careful about it, you might be able to add some dye to your finish to create a toner that matches the area under the rug. Use this toner to tone the bleached floor areas, feathering it carefully so you add color proportionally to the amount of bleaching. When the color suits you, let it dry, screen it lightly, especially at the transitions to the unbleached areas, and put on another coat of the clear finish. If you thin the toner slightly, it will extend your working time and level better.
Might be worth a try. Test it out before you commit.
