>I just got a Grizzly 14" bandsaw. My understanding is that OEM blades are generally not the best, so I'm wondering what blade(s) would be good to have; brand, width, TPI, etc. I'll probably use the saw for resawing, freehand curve cutting, the usual.
>The area furniture factories use Lenox and/or Sterrett blades. At least that is what the local saw shop stocks for them. There are a couple of guiding philosophies......1. You want several teeth in the stock being cut. So for 1 inch stock a 4 tpi blade will do but for 1/4 inch stock such a blade would not cut smoothly, and that is an understatement. 2. Smoothing the errors resulting from poor tracking is vastly harder than smoothing saw marks. I can guide a coarse tooth blade around a curve better than I can a fine tooth blade. 3. A cause of inaccurate tracking in resawing is clogged gullets. For resawing you want as wide a blade as the saw will accommodate and as few tpi as you can find to lessen the gullet clogging issue.
For general work I keep on hand a 1/2 or 3/4 3 or 4 tpi blade for resawing. For other work I keep on hand a 1/4" 4 tpi and a 1/4" 6 tpi. But some shops like a 3/8" blade as it is a compromise between the better tracking of a 1/2" and the ability of a 1/4" to make tighter inside curves. And I have one 1/8" 6 tpi for fine work.
I just bought blades for a daughter's new band saw. I got a 1/2 x 4 tpi, 1/4 x 4 tpi and 1/4 x 6 tpi. A 3/8 by 4 or 6 tpi could have been included depending on what the saw was mostly used for.
Hands down the cheapest blades will be had at a saw shop that welds them from stock rolls. The above blades cost $5 for a 14" saw. I use Misenheimer in Morristown TN.
>Thanks Bill, a light went on for me. I finally 'got' the teeth in the work thing.
I find my bandsaw to be somewhat hateful. I have a 14" Delta with a riser and don't get as much shop time as I would like. It "kills" me to find I have the wrong blade on the saw. Seems to take a long time to remove the old blade, Install a new one and tweak the guides. Some where between fifteen and forty five minutes. It seems the saw always has the wrong blade. I have a WWII combo blade on my TS and it does almost everything I want it to. And if I have to change the blade it takes less than five minutes. That's five in and five out. the bandsaw takes much longer both ways, if you get my drift.
I bought a dozen of half inch 3tpi blades that are identical and generally leave one on the saw. I can resaw with them and cut bowl blanks. Good for roughing down stock. I do very little fret work or thin stock. With identical blades waiting it only takes about ten minutes to change the blade. Much less fiddling with the guides.
I think the answer is two bandsaws. One for reviewing and one for curved work. I'm serious and if I had the money and the shop space, that's what I would do.
>I've very happy with the Highland Hardware resaw blade (Woodslicer?). I also use the Timberwolf blades from Suffolk Machinery and have been happy with those. For my work, I use a 3/8" blade and a resaw. Those seem to handle anything I need. Enjoy your new saw!
>Anecdotally, I have found OEM blades and "branded" blades to be inferior to higher-end replacement blades (including all those mentioned in this thread), but I can't refer you to controlled test data on the subject. I'm sure there have been comparison tests published. But, ultimately it comes down to how well the blade cuts -- speed, smoothness, accuracy, etc. Inexpensive blades are less painful to throw away if they don't live up to your performance expectations. Generally, better blades last longer and cut better.
Besides the number and type of teeth, which are specific to the immediate there are several other key variables that affect cutting performance. Art Gschwind, the blade guru of Suffolk Machinery, talks about approach angles, gullet symmetries and set patterns. Also, the way a blade is manufactured is important, especially regarding the set of the teeth. Stamped blades tend to have a far less accurate set than ground blades. Also, according to Art, the old hook and skip tooth patterns that have been around for half a century were designed for metal cutting. Neither delivers the ideal tooth geometry for wood cutting.
Of course, performance also depends on how well aligned your saw is and how much tension you put on the blade.
>Thanks for the replies. The saw came with a 3/8" blade. One thing I'm considering doing is making a few "bandsaw boxes", one in particular as a 70th birthday gift for my wife's mother, out of a bit of burl I got over the weekend. I made a "practice" one out of a planed piece of cedar 4x4. Didn't come out toooo bad for a 1st attempt, but on examples I've seen from people with experience, you really have to look closely to see where the bottom was removed, where the blade entered the body of the box to cut out the inside, etc. Blade thinness seems to be the main prerequisite. I'm thinking a 1/16" blade might be good for these. Grizzly says the saw will take blades from 1/8 to 3/4". I can see why an upper limit would exist, but why would the saw not accept 1/16" blades?
I see the terms "Raker", "Skip", and "Hook" associated with bandsaw blades. I'm assuming this refers to the set of the teeth, no? What is each particularly suited to?
>Here's a good link. To really tune your band saw, might I suggest getting Mark Duginske's book - "The New Complete Guide to the Band Saw". I've got the older edition and it helped me tune my old Delta 14" a lot.
>Suffolk Machinery has a great chart showing what type of blade would be good for what cut you are trying to make.
Look up the thickness of the board that you are cutting, and how tight a turn you need to make for that cut, and you'll see which blade to use.
You don't have to worry about the tooth pattern too much (hook vs. skip vs. raker vs. alternate set). In the vast majority of cases, there is only going to be one tooth pattern for the size and TPI of the blade, and the tooth pattern will be good for the type of cut that the blade is used for. For example, you're not going to find a raker tooth pattern on a 1/2" 3 TPI resaw blade.
>I want to thank Ellis and all the contributors to this thread for the great info contained herein.
Last week before I saw this thread I knew I needed to find proper blades (plural) for my Grizzly 16" bandsaw purchased in 2000. Through improper usage I dulled the oem blade very quickly after purchase and thereafter used the saw on a very limited basis. I searched this site (and others) and found a positive recommendation for Suffolk Machinery. So I called the 800 number and spoke with a very nice fellow named "Art" who at that time I assumed was a lower level employee saddled with the mundane job of taking phone orders. Now Art was very informative and helpful in explaining why I needed certain blades to perform particular jobs.
I placed an order for four blades with the fourth being free on their current promotion. The next day after ordering I discovered this thread and Ellis' comments about the Guru at Suffolk by the name of "Art".
So my order was shipped on Thurs 8/28 and I received it today (Sat 8/30). Comeon, three days from Long Island to Arizona, I think Art is really "Chris Angel" in real life.
BTW, I called Art back after discoveing his real identity to thank him for taking a lot of time to explain several things to this beginning band saw user.
I just cannot fathom better customer service than this company provides although Lee Valley is close. I haven't used the blades yet, but I have confidence they will perform as good as their customer service.
Thanks for all the help from the members here, BTW, "Art" is Art Gschwind the CEO and founder of Suffolk Machine. For those of you that already knew this I apologize, but this info is meant for bandsaw newbys like myself that didn't know. Good woodworking to all, John
