Veritas - Innovation in Tools
Need plan for router pantograph or duplicator
Phil Joines Krum, Tx
>I need to make a bunch of small plant name signs.Letter size about 1/4". Does anyone know of plans for a pantograph for a router or rotary tool? I could use a duplicator but I think a pantograph would be easier. Anyone tried the duplicator in Bill Hylton's book Router Magic? It rides on a cushion of air from a shop vac.
Re: Need plan for router pantograph or duplicator
Chuck in ND
>1/4" inch seems pretty darn small. Have you thought about contacting someone with a laser engraver ? Or maybe use lettering stamps.
>Have you seen how many letters there are in some of the scientific names? :>) And that's why I'd prefer to use an pantograph, so I can see what I'm doing. These will mostly be outside and need to last as long as possible so ink or paint are out. With the number needed I can't afford to pay some else.
Where are you going to find a router bit?
>Are your letters are going to be 1/4"? Or are you saying that the width of your "pen" stroke is going to be 1/4"?
Personally, I'd consider a Dremel tool with a rotary burr. Pencil your lines really heavy (or use a blunt awl) and trace with the burr. Weecher also has a reciprocating carver that would work (use a Flexcut tip though).
Bob Lemon Sacramento Ca.
>Phil, have you thought about using a hand label maker. I think they are available at stationery stores, maybe Harbor Freight, etc.
Paul Waddle
>Google up Copy Carver for a homemade duplicator. Also go to www.dust-n-shavings .com and look at his version of duplicator.
As for wood,buy some redwood,it will rout very well as there is very little grain resistance.
Good luck,I've got a mill-route,ieal for your purpose. look around and advertise for one-~150$ used. pw
Don Evans
>If cost is an issue, I would look into plastic engraved signs. You say they are small and with quantity I think you'll have hard time beating their prices.
Look in yellow pages or online google "engraved signs".
I did a quick search and come up with prices that I would not use my time to try and save on, your mileage may vary.
Your message gave me the impression that this is a freeby job just to save money?
Don
Curly Smith
>The Router Handbook by Patrick Spielman (1983) mentions the Sears and Black & Decker pantographs. You can still buy the Sears model for $55 (http://www.sears.com/shc/s/p_10153_12605_00925187000P) - note that the model "Reduces from pattern by 40 percent, 50 percent and 60 percent." so you'll be out of luck if you need other ratios.
Plans for a router pantograph are included in Woodshop Jigs & Fixtures by Sandor Nagyszalanczy (1994) that is intended to enlarge but swapping the stylus and router locations will make it reduce instead. Size reductions from 25% to 80% are possible with the simple jig.
Have you gotten a quote on the Laser engraving?
Eddie Pacheco: San Jose, Ca,
>Laser seems like the most economical for a lot of lettering. You would be doing the typing and layout, based on a format and file type needed by the Laser tool owner, on your computer. You could nest all of the plant names on a plank, get them burned, and then you rip and cut the blanks to your specs. You could possibly even do an extra set in case of a miss cut.
Another method would be to lay out the names on your PC, print out the list, make a reverse or mirror image copy with a toner based copy machine, and then heat transfer the mirrored names onto your blanks with an hot iron. Then the blanks can be coated with clear poly or lacquer.
Garden supply vendors *LINK*
Tom Dunlap
>There must be ready made garden tags from a nursery or gardening vendor.
Another option might be to contact a the FW Botanical Garden or Dallas Arboretum to find out about labeling. I haven't seen many labels at the Arb, which is more of a botanical garden and the FWBG is more of an arboretum :)
You may find that they could make the signs/tags for you in trade for some volunteer time.
The object of finding the engraving solution is what drives most of us to our shops though. For a lot less money and maybe just a little overtime pay, we would all be ahead on most projects. But that just isn't in it :)
I googled "garden labels name tags" and found these:
http://www.metalgardenmarkers.com/?source=adwords&gclid=CKmo2_Dnq5UCFRJxxwod1hgXbA
http://gardenlabels4you.com/labels.html
Garden Label Maker
Paul Waddle
>I just remembered,Wood Magazine did an article on making signs and constructing a panatgraph. Ask those people who have the back issues to search their archives. Best I can remember, its relatively simple to make. I think the Bill Tillman machine would do very nicely. I believe I would simply draw the whole name/leters etc, and use this as an aid,templates are nice,but not necessary unless you want every name(letters) to be exactly the same. Use larger pc of sign material aand then trim it to size.
>Thanks for everyone�s suggestions.
There will be a continuing need for these for our plants, at a local nature preserve, and a new nature oriented town park so I want to be able to make them myself. As LOML is a carver we have a bunch of rotary tools so that isn't a problem. There are several designs on the net and in Bill Hylton's book but they are much larger than I need and space in the shop is always at a premium. The commercial ones, like the one from the one from Sears seem to be too light weight for accuracy.
I think I�ll make one from �� x 1� aluminum bar stock ($26 for a 6� piece from MSC) with shoulder bolts for the pivots. It may not be stable enough to carry a full size router but an air engraver or dental type rotary tool should work well. Now all I need to do is figure out the hole spacing.
BTW, PC has a 3/8� collet available for the 690 router and it would hold end mills with a 1/6� cutting diameter and a 3/8� shank We use them all of the time at work on CNC routers. Unfortunately, I can�t use the machines to make my signs.
Marc
>Hi Phil,
I'm not sure what type of print you are looking at, but something I saw once may be a way to do it freehand. I'll try to describe it.
1) Consider a trim router with a red dot on top centered over the bit. This would be your stylus
2) use a piece of clear lexan (maybe 8.5" x 11") that has a tube mounted in each corner (perhaps conduit)
3) have a base that has some clamping to hold your workpiece and a post in each corner that aligns with the tubes from the lexan (maybe dowels)
* the lexan is on top, touching the router under it, with the workpiece clamped under the router.
4) Now, write or print your letters on a transparency and tape it to the lexan, or perhaps a whiteboard marker would work, and just look through the lexan to your red dot stylus to trace your work.
Just a thought,
Marc
