Curly Maple Bed
Curly Maple Bed
Curly Maple Bed
Marc
>Here is a curly maple bed that I did recently. It is Eastern King size. Sorry that the pic is not very good, but the next one of the footboard is a little better.
Re: Curly Maple Bed
Re: Curly Maple Bed
Marc
>The footboard. Boy, I wish I had about 500 hands to assemble this, as it is all mortise and tenon construction! This was my first use of hide glue :)
Also, the bolts are on the inside of the side rails and the nut that receives them is buried in the tenons in the headboard and footboard. I saw that in FWW (I think), and it works very well. Still rock solid.
Re: Curly Maple Bed
Re: Curly Maple Bed
Keith Newton, LR, Arkansas------WebKitFormBoundary
>Mark, I like what I can see of it. That is a nice clean design, and I'll bet it really looks great when you can see that wood.
I hope I won't be hurting your feelings to suggest that you try providing a little more light when you take photos of your work.
Woods like this really pop when you light them from the side, and a little forward. Even a couple of work lights would help.
How did you bend the top rails?
Re: Curly Maple Bed
Re: Curly Maple Bed
Marc
>Hi Keith,
My feelings are not hurt at all - a photographer I am not. Thanks for the advice, I will try it next time.
For the top rails construction was as follows:
The main top rail was cut to the curve. It was a little over 1" x 2". I then laminated the 1/4" bead on the bottom. After this I resawed in half and used a jig with a router to make the mortises in each half, reglued, and put the tenons on each end of the rail. To get the slats to fit nicely, I made their tenons a little long, dry fit everything together and used a router to follow the curved top and trim the slat exact.
After final glueup, the top cap is four 1/4" laminations 2 that are the full width, and 2 that just fit under the cap, but against the previously designed curved piece.
Let me know if that describes it...
Thanks,
Marc
