electrical
electrical
electrical
Ronald
>Need some HELP. I have my source coming in at the light goes from there to a switch. now i want to add a outlet. would like the outlet hot at all times but if i can't it will not matter. the light is a light-fan combo and has pull strings. i only have 2 wires coming from the light-fan to the switch and 2 wires from switch to outlet. how do i tie this mess together and not burn the house down. i do know how to wire most but want to see if i can do this with out having to have 3 wire and ground from the light. and or how to do with what i have. hope you can figure this out.
Re: electrical
Re: electrical
Chuck in ND
>You really need to call a local electrician. They know the code in your area, and they are insured.
Re: electrical
Re: electrical
>If I understand you, you probably can't do what you want to do. (you have a three wire feed to the light/fan, Hot neutral, and ground. The neutral and the ground go to the fan/light and the hot goes to the switch and back.) If this is true, the white wire in the leg to the switch is "hot" when the switch is on and you could/should mark it with black tape or a black Magic Marker. This means there is no neutral going to the switch and therefore you have no neutral for the outlet.
Re: electrical
Re: electrical
Randy Johnson Connersville IN
>If you are wanting to feed the receptacle from the switch it will probably be impossible without running another conductor from the light. I've seen some weird ways of doing things over the years but as a general rule if the power is at the light there will not be a neutral at the switch.
Aside from that, I think it is a VERY bad idea to put receptacles and lights on the same circuit. You might be better off finding a different (and better)source to feed the new receptacle.
Re: electrical
Re: separate circuits
Kneale Brownson dreaming of snow in N. MI
>Like Randy says, you don't want to power the outlet off the light circuit.
If something plugged into the outlet blows the circuit, you won't have any lights.
