airbrush woes
airbrush woes
airbrush woes
peter kolb
>I own a Badger 150 airbrush and I can not get it to spray water let alone paint. Passage of air in and out of the brush seems normal. Any ideas what the problem might be? Thanks for your help. Peter in south central nj
Re: airbrush woes
Re: airbrush woes
>Airbrushes are notoriously fickle. I played with several for a while with increasing frustration. I replaced them with a Sata top loading detail gun and have found lasting happiness.
Clint
Re: airbrush woes
Re: airbrush woes
charlie belden
Possibilities:
- feed tube from bottle to brush clogged
- small "air" hole in top of bottle is plugged
causing a vacuum to form in the bottle.
- mismatch of needle and tip, needle too small
and set too far foreward. When you pull
the trigger back it continues to fill the hole
in the tip.
Re: airbrush woes
Re: airbrush woes
Bill Howatt
>Most airbrush problems are caused by "dirt". Did you try all the cleaning techniques including disassembly and cleaning? Thorough cleaning and keeping it clean are part of airbrush life. When you consider the amount of cleaning required for a big sprayer it is not surprising that the little ones are a bit fussier. Be sure you use good quality airbrush paint - not general craft paint for best operation and reduced maintenance.
Bill
Re: airbrush woes
Re: airbrush woes
peter kolb
>Clint, thanks for sharing. Charlie excellent suggestions. Bill thank you for your comments. Peter in south central nj
Re: airbrush woes
Re: airbrush woes
peter kolb
>Problem solved. I installed the wrong spray regulator. Solution Large needle-large spray regulator. Thanks again for your help Peter in south central nj
