wood acclimating to new home
Mark Sirak
>I just bought some 5/4 white oak. How long should I wait before I glue it together for a table top?
Re: wood acclimating to new home
jan derr
>if the oak wasn't toppled yesterday you're probably good. If it's kiln dried; what are you waiting for? What"s the finish?
>What is your shop like? Is the air conditioned or not? How was the wood previously stored? Is the wood kiln-dried?
I usually have to recover a day or two after a lumber shopping trip :). For Kiln-dried (as previously said), I don't know if it really matters. For air dried - I'd wait a bit, possibly as much as a couple of weeks.
And if undried...
Kneale Brownson dreaming of snow in N. MI
>You should sticker it out of the weather and let it sit at least one year per inch of thickness before using.
>There are many variables in this. Is the wood thoroughly air dried or kiln dried? Or, is it green?
Assuming it is dry, either way, I would take a hint from the flooring industry. They recommend you store the wood in the house for a few days to a few weeks before installing it. If I have any doubt, I cut the pieces down to manageable size and store them in the house, often under a bed as I progress on a project. My projects tend to move in fits and starts, so I might cut the boards for the top and put them in the house while I work on the frame, then put the frame parts in the house while I make headway on the top.
You have nothing to lose by taking your time, except time. If you rush it you will find out later, maybe.
>Good Afternoon Mark,
Most of the stuff I use has been air dried, and mostly stickered, but not always, where I bought it. I assume it will need some stabilization time. I bring it into the shop and lay it on floor or bench, stickering it and weighing it down. I seldom try to work it unless a couple weeks have gone by. I may be over cautious, as there doesn't seem to be significant wood movement/twisting, bending , or crooking, happening in the last couple weeks before use.
George
