Lumber rack location?
Robert Henderson
>I'm fixing my basement up as a woodworking shop.
I want to put a lumber rack on one wall (I bought the Triton system from Rockler) so I can acclimate my raw wood stock to shop conditions.
I live in New Hampshire, so the climate variations are fairly extreme.
There is an alcove about four feet deep formed by a short wall next to the bulkhead entrance on one side and the furnace room wall on the other that would keep the rack out of the way, but I would be limited to lengths of wood not much more than 10 feet long.
My other alternative is to mount it on the longest wall (about 18'), but that would place it over the baseboard of my forced hot water heating system.
1. Would having the lumber rack placed so that one end is next to the bulkhead (where it would be coldest in winter) and the other end next to the furnace room wall (where it would be hottest in winter) cause any problems with uneven drying?
2. Would having the lumber rack over the heater baseboard cause problems?
I am running a dehumidifier to keep the humidity at about 50% and a fan to keep the air circulating, so maybe I'm being paranoid, but I'd rather get it right the first time.
Re: Lumber rack location?
Robert, you get high marks for this post.
Keith Newton, LR, Arkansas------WebKitFormBoundary
>You have given us all enough information to really give helpful answers. Most of the time, there would not be nearly enough information to understand the situation.
Although I have a few questions. Where do you buy your wood, and how do they dry / store it before you get it?
Do you have a moisture meter?
It is good that you are keeping the humidity under control. If you are also keeping a fan circulating the air enough, it may not matter.
If when you get your wood, and it has been exposed and picking up moisture for quite a while, or just air dried, I think being over the heat might have an advantage of being a little warmer. The warmer air is capable of picking up more moisture than cold air.
wilbur
>Disclaimer: I don't have a lot of experience drying lumber, but I do know about thermal properties.
My feeling is that having the rack over your baseboard heater wouldn't cause any problems, especially if you have a fan to circulate the air. If I understand you correctly, your primary concern is the increased amount of heat the bottom of your lumber rack would get compared to the top rack. Circulating the air goes a long way towards evening out those differences.
In any case, assuming you don't have your baseboard heater cranked up to blast furnace levels, the only variance really would be that the bottom rack would dry a little faster than the top rack. In which case, you should be fine. If you are super paranoid, you could also rotate the lumber in your racks from top to bottom, but I bet that will get old quick.
I have seen plans for outdoor solar "kilns" for drying lumber, which are just a shed made with clear plexiglass so that sunlight provides the heat for drying wood, much like a greenhouse without temperature control. I'm sure that the temperatures in there will be much more extreme than in your shop. If you get into your car on a summer day, you'll know what I'm talking about. Also, air dried lumber outside during the summer also probably goes through a greater temperature and humidity swings from day to night than in your shop. Either way has been used to successfully dry lumber.
>Could make a baffle from plywood or something to fit above the baseboard heater and below the lumber stack to direct the heat in front of rather than through the rack.
Re: Robert, you get high marks for this post.
Robert Henderson
>I buy my wood rough, from a large retail/wholesale lumberyard. The retail hardwood is in a huge unheated building that usually has the large overhead door on each end of the building open to the outside air. In other words, The wood is sheltered from rain and snow but otherwise it is effectively always exposed to the outside temperature and humidity. I don't know if the wood has been dried in any way before it's moved into that building.
After I get it home, I usually sticker it and leave it in the garage for a couple of weeks at least (the garage being my former shop). Given that the lumberyard is 40 miles away and my pickup gets 17 MPG, I will be buying it in larger batches in the future (several projects worth at a time). I'll still sticker it in the garage, but move a projects worth at a time into the basement a week or so before rough milling.
Yes, I have a moisture meter, but I have never gotten into the habit of using it and I'm not even sure where it is right now.
To clarify, my main fears are:
1. If stored near the bulkhead, the wood will lose moisture faster at the furnace room end than the bulkhead end and warp.
2. If stored over the baseboard heater, the wood might dry too fast and get checking on the ends. Although, the baseboard unit never gets more than warm to the touch.
If you good folk can reassure me that I'm being overly concerned, I will pick an option and get on with the project (and my life).
Thank you all!
Ken Platt (Granby, CT)
>I'm not anything like an expert at drying, but I think you may be overthinking this. AFAIK, the important thing is humidity and not temperature. If your wood isn't in equilibrium with the humidity, then you have to take the usual steps in drying wood: seal the ends, stack, sticker, ensure air flow. If the wood is close to or at equilibrium, then it's not going to move much regardless of temperatures.
If it were me, I'd dig out that moisture meter so I knew what I was getting in terms of wood moisture content. And I'd put racks in BOTH places, cause I'd end up needing it.
Ken
Who filled one basement room with wood, then put up a wall rack in another area, then had to make a freestanding rack, and still has wood piled up in the garage waiting to move inside the house, but at least my wife is happy that the front porch is clear....until I get to those cherry trees in the side yard....
Dale Lenz
Re: Suggestions
Dale Lenz
>Get two humidity gages that reads close to the same. Place one gage near the heater where your lumber will be and the other gage at the other end. Note the difference in humidity for a few day ~ week. Make a decision based on your information.
>I would go with #2. I don't think you have anything to worry about with what you responded with.
If the lumber which you are buying has been kd'd, it could pick up some moisture on the surface, if it sets on top of the stack for a while. If it is down in the stacks, if won't get much change.
If it has gained a little, what you have described should be good for bringing it back down, and there should be no problems with checking at this level of dryness.
