Re: glass doors on cabinet
Jim Dillon
>Jack,
If you need to replace the glass sometime in the future, I vote for a rabbet of some sort. The simplist is just to cut the rabbet, then fashion a strip of wood fastened with brass escutcheon (Lee Valley)pins. The corners can be mitered or not. The strip of wood can be flush with the door's stiles and rails or slightly proud to give a reveal. Tapering the strip adds a nice touch. Of course, the enclosure strip can be more fancey depending o0n the style of the cabinet.
For something a little more complicated, using an offset mortise and tenon works nicely and generates the strip of wood automatically. Although more complicated to do, the strip of wood matches in color and grain to that of the stile or rail.
For a description of the first technique, see Glazing Cabinet Doors by Tony Konovaloff, "Essentials of Woodworking Series: Woodworking Techniques", Taunton Press, 2000. The offset mortise and tenon technique is described nicely in "In the Shaker Style", Taunton Press, Chris Becksvoort, Build a Bookcase with Doors. Also in FWW #128, pg 80, 1998. I used this approach for my kitchen cabinets and think it looks nice. Hope this helps.
As an aside, I've found both the paperbacks mentioned above to be very useful.
Jim
