OT - Wood Siding and Vinyl Soffit
Tony V
>I have a cedar sided house with painted wood trim. The gutters need to be replaced. There are also a few facia boards and pieces of soffit that need to be replaced. I figured that while I have someone putting up new vinyl gutters that I would have them install vinyl soffit at the same time. When talking it over with the installer, we talked about cutting the siding at the point where the j channel attaches to the side of the house so that the j chanel lays flat against the house. he alternative is to put the j channel directly over the boards and have gaps where the boards overlap. This would also mean that if I needed to replace any siding that I would have to cut at the j channel to get the board out.
What is the best thing to do in this situation? Does anyone have any experience or suggestions. I guess that putting the j channel over the siding is more common due to reactions that I am getting from installers. Putting the j channel over the soffit is cheaper but I think it might look cheaper too. One estimate refused to cut for the j channel saying that I would be dissatisfied with the result due to chip out at the cut edge.
Please advise
Tony V
