OT Silicone Caulk
OT Silicone Caulk
OT Silicone Caulk
Sawman
>I caulked some glass window sashes on Saturday and the caulk is still tacky. It is GE brand. Any thoughts?
Re: OT Silicone Caulk
Dale Lenz
Dale Lenz
>The clean silicone should be dry to the touch, overnight. The white colored silicone appears to take several days. Purchased some white silicone instead of my normal clear a few weeks ago, opps!
Chuck W
>It must be old stock if is still tacky. it should eventually cure though.
Similar experience
>I used some white GE caulking last year. It remained soft, wet and sticky for months. I discovered that I had used an old (4+years) tube. I just never seemed to dry so I scraped it off, bought a new tube, and reapplied.
Happy Woodworking!
galen V
>Agree with Mark that product has shelf life and discount stores sometimes have old stock. High heat and cold reduce shelf life.
Not sure if you used a GE Acrylic latex silicone or RTV silicone.
Assume it latex type was not painted over before it got cured.
Assume bead not too heavy as if it skins over will never cure thick bead.
If installed in hot dry climate it is slow to cure as it needs moisture in air to cure.
Just thoughts.
Fred Davis
>Next time you are in a building supply or a hardware , you could do yourself a huge favor and buy some PolySeamFil adhesive caulk in 11 OZ. tubes.
It is far superior to Silicone , cleans up with water , takes paint perfect and you never have to worry about it curing or failing.
The only caveat I would mention , is that be sure any material you bond with it is not going to be removed in the future , it easily is the strongest adhesive I have used.
Comes in clear, several shades of white and colors if the store will stock them.
FredD
