Bandsaw Blades
Bandsaw Blades
Bandsaw Blades
Stokes
>Where does everyone buy their bandsaw blades? Looking to purchase a new blade for rough cutting parts before final milling. Smallest radius to be cut is 2" diameter.
Let me know.
Thank you,
Stokes
Re: Bandsaw Blades
Re: Bandsaw Blades
Dave's Not Here
>I get mine from Iturra Design in Jacksonville, FL. They don't have a website yet but they do have a toll free, 866-883-8064. Chances are good that the owner, Lou Iturra, will be the person that answers the phone. He's a very knowledgeable and patient gentleman who'll work with you to ensure you get the blade you really need and not necessarily the most expensive. Be sure to ask for one of his catalog. The catalog reads more like an encyclopedia on bandsaw use than a product catalog.
Re: Bandsaw Blades
Re: Bandsaw Blades
mdclor
>The people at Suffolk Machinery, makers of Timberwolf blades, have always been very helpful for me. Either timberwolfblades.com or 800-234-7297.
Re: Bandsaw Blades
Re: Bandsaw Blades
Dick Coers
>I buy coil stock on Ebay and silver solder the joints. I've been really happy with the results. I bought a kit at Woodcraft, but had to rework the jig a little. It only takes a propane torch to get enough heat. I use a disc sander to grind a skive joint at a 45 degree angle on both pieces at the same time. Only takes a couple of minutes.
Re: Bandsaw Blades
Re: Bandsaw Blades
Glenn Madsen near San Francisco
>What Dick does for himself, I have the local sharpening service do. I don't wear out band saw blades nearly fast enough to go through a coil of blade stock in ten years...
Re: Bandsaw Blades
I solder them too...
John in New Mexico
>Though I have some parts on order to fix up a blade welder, seems like its taking forever.
Silver solder works great, but is a little trickier than welding. Problems I've had are alignment of the blade and grinding off too much solder (it tends to mound up on the joint a little). Both can cause the blade to break before it gets dull. However, at $6.50 or so per blade, I can live with a few disadvantages!
Re: Bandsaw Blades
Lee Valley (a sponsor here) has good ones.
Dave Bair, Eaton Rapids, MI
