Klutter Kills Kreativity?
charlie belden
>I'm probably the only person who manages to cover every horizontal surface above floor level with "stuff" - in progress projects, tools being used on those projects, stuff to sharpen some of the tools used for an in progress project, clamps, maybe a pin nailer (at least I seldom use a brad nailer or finishing nail nailer), cut offs - in ply and hardwood, an oscillating spindle sander that's waiting for a permanent home, a random orbital sander, a handsaw or two, a mallet, a small ball peen hammer, a marking gauge, a square, . . .
In order to do ANYTHING, I seem to have to move EVERYTHING - several times. It's sort of like one of those little puzzles with the nine slide around plastic numbers - and 10 spaces - move this so you can move that in order to move this over to where that was . . .
Now some of the problem could be solved by working on just ONE project - 'til it's done. But that means perhaps not even starting another wild hare idea project. I guess I could do a quick sketch with some notes and file it away for later. Finding it later, amongst the accumulating layers of "stuff" probably would take a bit of time. It's a semi-viscious circle once the Klutter Syndrome gets started.
The downside of Kleanliness is the loss of serendipity - two objects amidst the mess - wonder what would happen if I somehow could combine this with that, or use that shape for this idea.
Now I know the first suggestion is gonna be "use the tool and put it away when you're done using it.". I've got two wall hanging cabinets a step and a half from the woodworking bench. BUT - when the woodworking bench gets cluttered up there's the table saw table, then the bandsaw table and the miter saw tables and when all the flat surfaces above floor level are full there's always the layout/assembly bench in the next room. The key is to maintain momentum - keep going 'til either the "thing" is done - or give up because moving everything in order to make the next part requires too much Klean Up time. Then things come to a screeching halt - days go by in avoidance - followed by three days of Where The Hell Am I Gonna Put THIS - and - Do I REALLY Want To Save This Piece of (Ply, oak, maple, veneered panel, . . .
Often a solution becomes a two day project - build some racks to store the various boards and ply that Have To Be Saved, reorganize a cabinet to create more storage space, hang some stuff on the wall, . . . Then the day and a half or two day Klean Up turns into a 40 hour JOB.
By the time the Klean Up is completed the Kreativity thing has atrophised, or gone into a Koma. The work space is ready to go - The Muse isn't.
How do folks afflicted with the Klutter Thing strike a balance between spontaneous serendipity and disciplined productivity?
HELP!
charlie belden
OH LOOK - if I glued this to that and mounted it between centers on the lathe like this, then . . .
