Angles on back of corner cabinet.
Jack Schlachter
>This may sound trivial to some but I'm having the hardest time trying to figure the angle cuts on my sides and back board of a corner cabinet. The back board is 6" X 63" X 3/4" and the sides are 21" X 63" X 3/4" and I drew out a pattern on a piece of plywood but working flat like that it's hard to figure the angle cuts. I'm assuming you make these long cuts by setting the table saw at an angle and cut it the length of the board? Thanks ahead of time guys...and gals.
Jack
Re: Angles on back of corner cabinet.
George Koch
>Jack,
If your joining the board together by butting one to the other the rips is 45 degrees. If mitering they are 22 1/2 degrees. George
doug f, san clemente, ca
>Jack - If I'm reading your post correctly, then the way I make corner cabinets is to make the corner (back) angle 90 degrees and use a dado; very strong and much easier to assemble. Just be sure to adjust the width of the sides to compensate for the dado.
The angle on the front (i.e. for a face frame,) is at 22.5 degrees and yes, it's ripped along the length of the sides.
I hope this helps.
Doug
Jack Schlachter
>45's and 22 1/2's would work if everything was equal but my customer wants a certain width in front and a certain depth so my angles are not common but arbitrary. In laying out work on a flat surface, how do you determine angles?
OK, I'm confused...
>If you know the finished dimensions, depth, front, etc., can you simply lay out the structure full sized and measure the angles with a bevel gauge and a protractor? I'm probably overlooking a very obvious problem, but it seems like a relatively simple calculation.
Doug
You could use trigonometry..
>Or you can just figure it out.
Because it is a corner cabinet, you know that the front angle will be 45 degrees (assuming a square corner). Hypothetically, lets make it a triangular cabinet. The law of triangles says that the total of the angles is going to be 180 degrees. As the back corner is a 90 degree angle, the front angles will be 45 degrees. (90 + 45 + 45 = 180).
Now, if we take our hypothetical corner cabinet and cut it off so that the front is only 6" wide, the sides would still be equal. As the corner is 90 degrees, the side angles would have to be 45 degrees.
The angles of the back aren't going to change. The angles of the front pieces aren't going to change.
Now if the side pieces are unequal, you would have to calculate the angles. If you are interested in calculating the depth, you could use trigonometry and the law of sines to do that (B * Sin A = h or 21" * Sin 45 degrees (0.7071) = 14.85"). But I think I'd rather measure.
Now, you said in your original post that the customer wanted a particular width across the front? Same thing - all of the angles would be the same. The dimensions of the sides would change.
Give more data. The common angles should work.
Dave Anderson (PacNW)
>Do your layout on the plywood, then bisect the angle with a compass. Match the bicseted angle wth a bevel square. you can either use the bevel to set your saw or read the angle with a protractor.
Jack Schlachter
>Thanks all for your input. I'm going with the triangle shaped cabinet with no backboard. It makes it a little wider than he wanted but it will also fit the corner better and give the bottom doors a more asthetic look. More questions, see new post.
Thanks again,
Jack
