mdf edge fastening
mdf edge fastening
mdf edge fastening
Jerry Gibbs
>what's best for fastening into the edge of mdf? Jerry Gibbs
Re: mdf edge fastening
Re: mdf edge fastening *LINK*
John McGaw
>Question: do you mean fastening two pieces of MDF together as in building an MDF box? Or are you referring to attaching an edging piece, as in hardwood, to MDF? Does the fastening need to be invisible?
If invisibility isn't a requirement then you'd be hard pressed to beat the sort of screws used for particle board cabinetry. I've seen them called by different names but the link below shows the sort that I used most recently for assembling a wall of bookshelves which had MDF carcases. Very strong and very easy.
For blind fastening of edging or whatever a spline or biscuits are nice. I used biscuits to fasten hardwood edging to the movable shelves in by bookcases and had no problems.
MDF Screws
I agree
Ellils Walentine
>Fiberboard (MDF) is very unforgiving for edge-screwing. The only way I've found to even begin to do it effectively is to drill accurate pilot holes and use Confirmat (or equivalent) assembly screws. These have very thin, knife-edge threads that cut their way into the soft center of MDF and yield the best thread-pitch to pullout ratio. The European cabinet manufacturers use them exclusively for this kind of work.
That said, you will still need to engineer your cabinets carefully to make sure you have the requisite strength in all dimensions.
Ellis Walentine, Host
>I don't know the correct name, but the type of fasteners often used to hold cheap particle board furniture together might work well depending on your application. These have a side-threaded metal barrel the fits into a large diameter hole drilled through or part way through the thickness of the panel. A long machine screw fits through a hole drilled into the edge of the panel and secures the second piece tight against the edge, using the barrel as a nut.
