OT Questions on Hardie Plank Siding.
>This is somthing of an academic question becasue the job is over and we used AZEK PVC lumber.
The house I am working on has sound exterior trim (soffits and facia), but my cousin wanted to cover them. So we used the AZEK and it has worked well so far, but it very expensive.
I suggested we laminate Hardie Plank siding over the existing trim. The Hardie instructions specifically say not to use it for trim but I wonder if it would not have worked well over the facias and rakes. Any Thoughts on this? Amy experience?
Re: OT Questions on Hardie Plank Siding.
Pete LaBelle
>On a Habitat house down in Pass Christian, MS, we used Hardie plank lap siding on the house, but there was a special Hardie trim board that was approximately an inch thick used for trim around windows, doors & corners. Width came in approximate 4 & 6". I'm guessing that using the siding as trim may not be stiff enough to remain flat when cut to narrower strips. Only guessing here though.
Lee Gordon
Re: OT Questions on Hardie Plank Siding. *LINK*
Lee Gordon
>Hardie says you can use wood, composite, vinyl, fiber cement, or pretty much any kind of trim along with thir siding. They do, however, make their own trim boards.
Hardie Trim
