Re: Ebony Bending Question
MikeW
>Hi Jim,
The only picture I have is of a box. The circular cut out shows a piece bent and glued in place. Don't have a picture of the completed box. This was done a few years ago and it has remained just fine.
For smaller pieces, I usually begin by placing the piece one the top of a container of wider where the ends of the piece to be bent barely overhang the container.
The container is placed in a microwave for several minutes on high, until the steam starts. The piece of Gabon then placed on the container. The microwave set to keep the steam rising off the container.
I can often get smaller pieces bendable in about 10 minutes. Really, it depends on how much steam is generated. Sometimes it takes a bend and remains, sometimes it takes a couple tries to fully bend it.
I use forms, even for smaller pieces. The forms are for both sides of the bend. Sometimes on a simple bend like this one, I use a solid form--here it was a ceramic coffee cup of a slightly smaller radius than I needed--and a strap to pull it around and tight. The cup then had hot water placed in it. Everything allowed to cool way longer than I thought was needed.
The Gabon stuff is still brittle, it really likes steam. On anything longer/wider/thicker, it takes a small homebuilt steamer using even a tea kettle, small pipe leading from the spout to a larger piece of PVC pipe.
I have also soaked pieces in broiler pan of boiling water for several minutes and had success--just make sure it is longer than needed like someone mentioned.
Oh, and wear gloves. The stuff is amazingly hot...
Take care, Mike
