Re: OT: Lawnmower problem
Kneale Brownson dreaming of snow in N. MI
>Just went through this with a mower that stumbled a lot the last half hour it would run and then got so it wouldn't run at all. I found the flexible tube between the air filter housing and the carburetor had aged (darn thing is only 14 years old) enough to split and allow dust to get sucked in. I replaced the tube, but the engine behaved just as you describe.
So I removed the carb, soaked everything in mineral spirits so I could scrub off the years of grime, took it mostly apart, blew out the orifices with the compressor, replaced the needle and seat (inexpensive kit) and reassembled with new gaskets (another inexpensive kit), and after ~$12 I had a running mower again.
Carbs on these things generally are quite simple. After cleaning up the outside, just take it apart on a good clean surface and note how everything goes. Blowing through the fuel intake removed the old needle valve seat for me and I used a rubber-tipped air gun to make sure there was nothing stuck in any of the other openings.
If you find the float to be something other than a hollow copper fixture, you might want to replace that too. The plastic ones tend to deteriorate over the years and with changes in fuel supplies.
