Way OT-Installing New Shower on Concrete
howard
>I am going to expand my bathroom downstairs(I got a new shop added to the house, my wife gets a new bathroom!!!) I want to install a new shower but it will be on the concrete slab. I know that I can either break through the slab to install the drains(would have a plumber do this) or I can raise the floor to avoid cutting through and I can do the work. Anyone with experience with this, advice, etc. Thanks for the help.
Re: Way OT-Installing New Shower on Concrete
The deciding factor
>The decinding factor would probably be ceiling height and headroom.
Breaking up a concrete slab to put in plumbing is bad, but a short shower is worse.
Happy Woodworking!
Don at Central Illinois
>I'm going to have to do this for my daughter and son-in-law this fall. I'm going with a raised platform and do the plumbing myself.
Justin Szeliga
>Location of the drain out of the building is the first part of the equation. The question comes down to is where is the line out of the house in relation to the bathroom location & what is it's elevation? Is it above the slab or below? If it is below the slab is the bath close enough to make opening the floor easier than building a platform? With a platform will you still need a pit & pump? If you need a pit & pump, is digging for that easier than doing a low profile pump, assuming you have enough headroom for that?
Your best bet is to talk with a contractor or 3 about it.
Peace
Justin
Kevin Mac Luskie
>While I have not re-done a bathroom on slab yet (probably will next year) I have done quite a bit of tile work in all parts of my house. Breaking out the concrete and redoing a new drain isn't beyond the abilities of a competent do-it-yourselfer. I would suggest visiting the John Bridge Tile Forums (http://www.johnbridge.com/vbulletin/forumdisplay.php?f=1). Do some browsing, reading searching, and those post some questions and pictures of your particular project. The purpose of the form is for Tile advice, redoing plumbing for bathrooms comes up frequently.
While I fine woodcentral to be one of the best places for advice on all of my wood related projects and tools, I don't beleive you will find a better reference online for tile and relate installation issues than the John Bridge forum.
>Howard,
I did exactly the same thing in the last house we lived in. I installed the drain and trap by cutting a channel in the concrete floor. This was easier than I expected. I have an industrial hammer drill so I drilled a series of holes into the concrete on the sides of the desired channel. Then I used chisels in the hammer drill to cut away the concrete between the holes. This was easier and faster than I had expected.
Kneale Brownson dreaming of snow in N. MI
>I've repaired/replaced drain lines under floor slabs by just hammering out the concrete. The hole across the floor wasn't pretty, but it went fairly rapidly. Finishing was by patching the concrete and replacing flooring.
