Urethane Glue on Chair Legs
Paul Leuba
>I have inherited an attractive antique side chair from my mother and have just discovered that one leg is broken just at the point where it supports the seat. In order to do a proper job of repairing the undercarraige of the chair, I believe I should remove all 4 legs and disassemble the connecting spindles. Then, after turning a replacement for the broken leg, I should clean, glue and reset the leg assembly as a unit.
This seems to me to be the ideal approach, however, the leg assembly must have been previously repaired because there is a considerable amount of excess glue that has bubbled out around the 4 leg sockets. Although I've never used urethane glue, from other postings I've read on WC, I suspect that it was used on a previous repair job on this chair.
Is there a recommended approach to disassembling this chair undercarraige in consideration of the possible use of urethane glue?
Paul in Hunt Valley, MD
