Re: Bar Mold Miter Angles for 90 & 120 degrees *LINK*
Rick Christopherson
>I started to answer your posting yesterday but got too busy to finish it, and I fully expected several other people to chime in shortly afterward. Well, now that I see that no one has come forward to help you, I will give you a link to a calculator to help out.
Before I do, you should know that if you put spacers under the moulding when you cut it, that your cuts will just be standard miter cuts. However, maybe your moulding won't permit this type of spacer, in which case, you would be forced to make compound miter cuts.
To use this calculator, you need to figure out the difference in the angle the moulding makes to the horizontal plane when resting on your saw versus when resting in position on the bar. This is your slope angle, and I suspect yours should be just a few degrees, say maybe 5 to 10 degrees (oops, I see that you said 30 degrees, but nevertheless, this does seem pretty steep).
Also, your corner angle seems suspicious, unless your bar has a really sharp corner. Your corner angle (for this calculator) should almost never exceed 90 degrees, plus or minus a few degrees. Instead of 120 degrees, I believe you mean 30 degrees, which is a rather soft corner instead of the really sharp 120 degree corner. (Don't get me wrong, your 120 degree number is mathematically correct, but this calculator was designed to work like woodworkers "think", and woodworkers normally think of a 120 degree "mathematical" corner as a 30 degree "mitersaw" corner.)
The PDF below contains an excerpt from an early draft of the Festool Kapex mitersaw manual, and contains a built-in electronic calculator as well as a graphical explanation of how to apply it to many applications. Because I put this together for review purposes of an early version of the manual, it also contains additional information that you did not ask for, such as using the 4-cut method for calibrating a saw and its associated built-in calculator. There are a few typos in there, but the calculators are accurate.
Compound Miter Excerpt from Festool Kapex Manual
