OT.....Yellow Jackets!
Marv....... Northern California Lake Co.
>I'm at war with Yellow Jackets....What's the easiest and best way to kill them when they nest in the ground?
So far, the best thing I've tried is hot water and Tide. I can't use any fuels due to underground migration of the chemicals.
Thanks,
Marv
Re: OT.....Yellow Jackets!
Rob Stokes in North Vancouver
>I had a huge wasp nest in a portion of the house I could not get to. Rather than chemicals, I set up the shop vac at the entrance and let it run for several hours/day for several days. Ended up with a carpet of dead wasps about 4" thick in the bottom of the vacuum (I'd squirt Raid into the vac at night and plug all holes). Highly recommended.
Rob
Dale Lenz
Dale Lenz
>Marv: What I tried years ago due to the YJ near my trees was Sevin dust. Had some 5% Sevin and threw a hand full on their entrance hole. Next morning seen a few YJ outside the nest slowly moving, but by evening no activity, don't suggest jumping up and down near the hole, to make sure :").
>Hi Dale,
Where do I get sevin dust? Is it a common insecticide? How much do you put around the opening of their nest? Their holes are quite small, only about 1" diameter in some cases.
I'm grading the area where they are with my tractor and almost scraped over them.
Thanks,
Marv
Re: OT.....Yellow Jackets! -- Fire!
Vincent Booth
>I grew up in the country and we would just pile brush over the nest and burn the out. Might work on a small scale.
>I'm in a highly combustible area and can't take the risk of sparks setting the rest of California on fire.
Thanks,
Marv
Vincent Booth
>I like the shop vac idea.
If you use a wet/dry vac with an inch or two of water to drown the little guys, you might not need the raid.
Vincent Booth
>Well, there is that to consider. I was in the Ozarks of Arkansas when I did this. Much more humid and less fire risk.
What part of CA?
We just moved from San Diego to Fort Worth.
>Rob,
I thought of using my shop vac, but the nests are about 2 or 3 hundred feet from my house.
Marv
>I'm north of SF, east of Ukiah. Next to Clear Lake.
Dale Lenz
Dale Lenz
>Any place that sell insecticide, Wal-Mart, hardware store, nurseries, it's cheap in price. Sevin comes in a powder form, different stength, I normal have some 5% laying around. I just reach in the bag and grab a fist full and carefully throw it on their entrance hole as I'm quickly walking past. The incoming YJ will carry the powder into their nest, works for me. Might want to be fully clothed when you attempt this to be safe. I've never gotten stung while doing this, but there a first time always.
>Thanks Dale,
Sounds like an easy thing to do, I'll try it. I read that the best time to mess with them is early in the morning when it's the coolest in the summer months.
Yellow Jackets only use their nest for one season. During the colder months they all die off except for the queen. When things warm up, she leaves all the dead carcasses behind and goes and finds another nesting place and builds another slavery harum.
Yellow Jackets can sting over and over and they also bite. Honey bees can only sting once, then they die.
Marv
Yellow Jackets, a story
Bill Hammond, Oregon Coast
>About 25 years ago I was working on a job site when the owner asked how to get rid of the yellow jackets that had nested near to where we parked our trucks. The mutual consensus of those present was that he should cover the nest hole with screen and pour some of his chainsaw gas into the hole and then set it afire. It seems that none of us had thought to tell him not to use fiberglass screen.......
Well the fire and gas really aggravated those little devils and as soon as the fire had melted a hole in the screen angry yellow jackets, on fire, swarmed from the nest. Those who were thinking quick jumped into their trucks, others of us who were not thinking that fast soon followed with flying fire at our heals. And.... the property owner who was not thinking at all ran. He made it to the river before he got stung too badly (I think rolling down the bank hurt more) but the trail of fire took some time to put out.
And the next day, there were yellow jackets milling about where the nest was. A front end loader and a bucket of muck put an end to them. We all still avoided parking there though.
Then there was the guy who burned down his house with a propane torch and a wasp nest, but that happens at least once a summer.
Bill, who is still learning that if there is a way, someone following your instructions will screw it up.
Vincent Booth
>I just read a suggestion that I felt compled to pass on, I got a kick out of it.
If you have skunks or raccoons in the area, try pouring a little honey near the hive entrance. The skunks/raccoons will find the nest and dig it up. Apparently they love to eat them.
I've done this
Lee Schierer - McKean, PA
>Get some moth balls or moth crystals. Pour about 1/4 cup down the hole after dark. Immediately stuff a wadded up plastic shopping bag into the hole. Wait 2-3 days and remove teh shopping bag. Recycle the bag and your problems, at least teh stining kind, will be gone!
Lee - Who unsuccessfully tried to out run a bunch once on a riding lawn mower when he ran over their nest while cutting grass.
Re: I've done this
Fred Davis
>I have some friends that live above Jackson in the gold country and they every year put out a bucket about half full of water and suspend some meaty barbacue ribs above the water , the jackets go crazy for the meat and fall in and drown.
Doesn't take long to reduce the local population wasps and is fire proof.
BTW , did Clear lake every clear up ? ;-))
FredD
Re: I've done this
>Hi Fred,
No, Clear Lake has never been "clear" as far as I know. It is a fairly shallow lake and algae thrives here because the sun can get down to the bottom. This is the worst time of year for the algae stench and the lake water looks like pea soup in certain areas.
Marv
>We have both skunks and raccoons. They actually did me a favor and dug up one of the nests, making it easy to pour a five gallon bucket of hot water and Tide detergent down the large hole. It acted like a big funnel. That particular nest is now eliminated. After the soap treatment I filled the hole with dirt and then laid brick on the dirt to keep the skunks from digging it up again. They do a lot of damage to the nest, but they don't get all of the bees. Some of these nests can have thousands of bees and they go deep into the ground. They will often times take over a gopher hole and their tunnels.
Marv
Funny story, at least from here....LOL
my successful solution
Bill Tindall, E.TN
>I wait till dark and pour a pint of gasoline in the hole. Never fails to kill them every time. I hate the !@#!! things and any death is acceptable so long as they are dead the next time I mow.
Recently we have had a skunk on the farm and it has eliminated several nests and saved me the trouble.
Re: Yellow Jackets, a story
>>Well the fire and gas really aggravated those little devils...
Around here, they pour gasoline into the hole and ignite it only in the middle of the night. At that time, all the little satans are cozy in the house. But never ignore gasoline safety - I knew a guy who had the flame on a brushpile follow vapors back to ignite the can next to where he was standing. Much safer is kerosene or diesel fuel (my favorite.)
The last nest I killed I simply sprayed wasp killer into the hole. Worked well for white-faced hornets a few weeks ago too. I use one can in each hand - one is the liquid and the other is the foaming type. The liquid goes deep in the hole and the foam plugs the entrance.
I've used the sevin method, but I prefer liquid sevin in a garden sprayer. Stick the wand down the hole (in the middle of the night, again) and saturate the nest. I use that method successfully for carpenter bees as well. BTW, the local farmer's co-op sells sevin in a variety of forms. (Please never dust sevin on blooms of any kind or you may poison the local honeybee colonies.)
And I do like the skunk method as well - I occasionally find holes around the farm with chomped nesting comb. Although, it makes me wonder if the wasps themselves simply go somewhere else and rebuild.
Re: my successful solution
>>...any death is acceptable so long as they are dead the next time I mow.
I know a guy whos grandfather was killed when he stirred up a nest of yellowjackets while mowing with the tractor. He jumped off the tractor, fell, and was crushed by the moving tractor. I know another guy who was badly injured when when he tried to jump off his horse when they got into yellowjackets. Best thing to do, I think, is stay on and go like the wind - horses are fast.
When mowing/bushhogging in the summer, I always wear a long-sleeved shirt and a net over my entire head, hat and all. These are available in the hunting section at Walmart, sold as camouflage to bow hunters. In the toolbox on the tractor, I also carry a suction device called the The Extractor also available at Walmart (camping section). In the event of a sting of any kind, this little device will instantly move the poison, the pain, and minimize the effects.
WAIT! Your in California...
Craig in Silverdale
>Have you checked to see if they are on the endangered species list? You may have to move.
Re: WAIT! Your in California...
Stuart Hough
>One thing I've heard is to pour a strong solution (about 50/50 with water) of Dawn dish detergent down the hole. There is something in the Dawn that gets into the pores (where they breath) and sets off a reaction that basically liquifies their insides. It also causes the gut to pop if they get enough in. I personally have only used this on fire ants, but it did the trick. It also works on wasps if they fly through the spray.
Kneale Brownson dreaming of snow in N. MI
>They don't fly in the dark. That's when I'd try the Sevin treatment. Personally, I use those 60-foot spray bombs that will only spray about 40 feet. It'll knock down flying bees and has a residual poison.
