ADVERTISE HERE - FREE TRIAL
OT - Painting a steel garage door
Tim Greif - West of Chicago
>Juat had my house stained and the painters got trim paint on one of the steel garage doors (which are 19 years old). They tried some sort of solvent to get the paint of and just made it look like someone smeared grease all over it. The original factory brown door finish is a bit chalked and the cleanup sort of restored the gloss to those areas. Now even though the doors (three car garage) are old and somewhat chalked, they looked just fine bacause they were uniform. Now I have one door that looks like crap.
The painters (CertaPro) said they'd use some product to clean both doors so they looked uniform. But now they're balking and saying they may have to paint the doors to solve the problem. My question is what needs to be done to prep a factory finish on a steel garage door, and what kind of paint should I be having them use?
I know there's a couple professional painters on here and hope they will chime in.
Re: OT - Painting a steel garage door
Tony - Memphis
>I'm no pro, but mine is covered with regular old latex trim paint. It was sprayed on and looks and works great.
Tony
Same here!
Lee Schierer - McKean, PA
>When we changed the color of our house, we also painted the garage doors. I used a Wagner Power painter with latex paint. It has worked for 3 years so far with no signs of a problem.
Lee
Justin Szeliga
>I'd check with a couple of paint stores (not BigBox paint departments) & see what they say.
Peace
Justin
Jason Roehl in Lafayette, IN
Good advice here.
>Checking with a dedicated paint store is generally good advice. Better if you can talk to a manager or assistant manager, as sometimes there is high turnover among the part-time help. You'll probably just get the advice to clean the doors first (either pressure wash, or scrub-brush and TSP solution), then two coats of a quality acrylic exterior paint. A couple people said "latex", but they probably really meant "waterborne"--latex is pretty much just a legacy term when it comes to exterior paint.
Jason (done a little painting...okay a lot...it puts food on the table)
Re: Good advice here.
Pete LaBelle
>Clean off the chalk with TSP till your fingers don't get any transfer. Acrylic Latex will work fine. A better finish is had if you can spray it. Painted my door 2 times now in the last 16 years. No issues with bonding of the paint.
Note that after painting an overhead door, park the door partly open so all the joints can be painted and allowed do dry. Even after dry, it'll make a noise as each joint flexes open, as the paint will always remain kinda soft.
