Raising a plunge router in a router table *LINK*
Dan Mitchell
>I'm almost finished with a router table I'm building, only have to connect up the dust removal, do the wiring & rig up a means of lifting the router to adjust the bit height. On this last issue, I'm leaning towards a shop-built crank arrangement under the table, like in the picture below, which fortuitously even shows my router model, an Hitachi M12V. I would prefer a set up that allowed height adjustment from above the table. Is this possible with such a plunge router & without one of the expensive lifts? Table insert is a Veritas round type (link below).
TIA
Dan
Veritas baseplate
Re: Raising a plunge router in a router table *LINK*
>Dan,
I "built" a similar crank for my Ryobi RE-600, but it's not an above-the-table deal. I have also seen people use a flexible shaft attachment and then bring the crank to the outside of their table cabinet with a 90� turn.
I always thought this WoodCentral article was grea
Howard In Toronto
>I don't agree with narrowing the threaded rod - you can find metric threaded rod pretty easily.
http://www.woodcentral.com/articles/powertools/articles_637.shtml
He also wrote a companion article on how to build an outboard "button" to lock down the shaft while using this rig.
HTH
Howard
Tony - Memphis
>I've been using a Router Raizer with my Hitachi and really like it. I started with a homemade job, but I like the Router Raizer a lot better. It was easy to install and works very well.
Tony
Instead of a crank . . . .
Alan in Little Washington (NC)
>Instead of a crank you can do this- a powered lift!
All it takes is a small reversible gear motor, a cheap (HF) right angle chuck (I didn't want the motor to hang down into the drawer below), and a few shaft connectors.
Hey Allan. .
>Good Morning Allan,
I sure like that arrangement. Innovative and neat. Although I happily use a JessEm Master Lift with my fixed base 7518, that device you put together deserves my applause.
George
Re: Hey Allan. .
>My rig is connected to a WoodPeckers Plunge Lift which has the 32 TPI lead screw.
Dan Mitchell
>Thanks for the replies. Since I already had the 3/8-16 all thread, I think I'll make one of the hand cranks to get up & running (a typical shop-building irony: you need a router table to make the shaft for the crank). One limitation I have is this is my only router, so I do want to be able to use it outside the table fairly easily.
Dan
Re: Hey Allan.
Dan Mitchell
>That is cool. What are the specs on the motor (rpm,etc). Looks like it has a gear reduction.
Dan
Re: Hey Alan. *LINK*
>Sorry I missed the follow-up question.
The motor is from the Surplus Center and is a 250 RPM 1/40 hp reversing 115V AC motor(see link). I have a 32 tpi leadscrew on my router lift and wish the motor was about 300 or 320 RPM and 1/20 hp. But it was cheap ($14) and works ok, I just need to keep it lubed.
Gear Motor
