Question for Chair Makers
Keith Newton, LR, Arkansas------WebKitFormBoundary
>I was just going through some of my lumber stacks looking for some cherry for a project that I have coming up. Most of the cherry that I have is not dry enough to use yet, although I have a good bit of 12/4 which I sawed in 04 from a fairly crooked tree. I was thinking I might use it for chairs where the back leg needs a good bend for the legs and back to tilt.
Do any of you look for wood which has grown in crook for this purpose? I would think this may be a little hard to find on the market, because it just doesn't make for a very pretty stack, and would probably get knocked down into the lowest grade.
Since I am only needing really small parts for this current project, I feel nuts for even thinking about cutting any of this up for tiny parts.
If any of you have used grown crooked wood for this kind of project, I would like to hear from you as to whether there have been issues with the parts changing shape more than normal straight grained wood.
Also, What about value? If you were going to make some chairs where you needed a good bit of sweep for the grain to follow the leg into the back. I know how much work is involved in steam bending, then waiting for it to dry, so do you pay more for wood like this, or just feel luck when it is sold in the cheap pile.
