Re: OT - The PC Sound Track that Won't Quit
Alexander Grigoriev
>If you've received or downloaded a file from untrusted source, and the file didn't have a known good media file extension (like .wav, .mp3, .wma), but had .exe extension instead, it's actually an executable file, which could do all kinds of non-kosher stuff to your computer, such as install a keylogger to steal yor passwords, etc.
NEVER RUN EXECUTABLE (.exe) FILES THAT CAME FROM UNTRUSTED SOURCE.
First, disable that stupid "hide known file extensions> option. Go to Control Panel->Folder Options; open "View" tab, uncheck "Hide extensions for known file types", hit OK or Apply.
Second thing you want to do is change your user account type to Limited User from Administrator. There is a separate Administrator account, and only it should be used for administrating, such as program and device installation.
Logout from your account (to the login screen). Hit Ctrl+Alt+Del twice. You will see a login dialog. Type your administrator account password (if any).
Go to Control Panel->User accounts. Select Change another user. Select your "resular" user account. Then click Change account name or type. Select Limited User, hit OK. If you have multiple user accounts, do the same to all of them.
If all your regular accounts have "Limited User" type, you don't even need an antivirus now.
