Dove tail jig
Bill P
>I am interested in a dove tail jig. I want to use it for mainly drawers and boxes. What brand does everybody else use and what size do you prefer? Any help will be appreciated. Thanks, Bill
Dove tail jig
Bill P
Re: Dove tail jig - my vote
North of the Border
>Leigh Superjig 12" (under $200) - more than enough for regular drawers and boxes (thru, half and finger joints). For trunks or dimensions exceeding 14" (rarely), I fall back to handcut dovetails. Like Honda and Toyota cars, Leigh's have high resale value. The vac accessory does a great job, though not essential.
Re: Dove tail jig
mdclor
>Bill,
I have the 24" Leigh D4. The jig is very versatile and the instructions that came with it were great. I think it has been replaced by a newer model now, but the company is top notch and I am certain that all their products are superior. I have never used the full width, but I would have kicked myself if I ever wanted to make a blanket chest and didn't have the capacity.
HTH,
Merle
Re: Dove tail jig
Dan Mitchell
>A 2006 FWW review gave the Leigh D4R & D1600 "Best Overall" & the Porter Cable 4212 "Best Value". I'm also looking at these & am leaning toward the PC.
Dan
Re: Dove tail jig
Dan Donaldson
>Dovetail saw, chisel, and mallet;-)
Ducking and running.............
That said, I have a leigh jig that works well, at least it did the last time I had it out about 2 years ago. It is really not as complicated as some make out. You just have to think about how it works and the instructions all make sense. I do most stuff by hand, but if I were going to do a kitchen or something like that, I would get it out.
I would recommend that you try a few by hand just for fun. They really are not difficult. If you have only a box or a couple of drawers to do, it is faster to do by hand than to get out the jig, router, and bits and set them up. Also, you can make DT's by hand that are not possible with any jig out there.
Re: Dove tail jig
Scott in Montana
>I had a 16" Leigh for many years but got up my courage and learned to cut my dovetails by hand and sold the Leigh.
Well recently my curiosity was piqued by the 24" Akeda jig. While it's too new to form a conclusive opinion, so far I like it a lot.
That said, it, like the other top jigs, is not cheap.
I'll have more time this Fall to play with it further.
Scott
Re: Dove tail jig
Dick Coers
>Keller, Keller, Keller
The most underrated fixture on the market. No big marketing, just a dang good fixture. Once the jig is set, unless you drop it, the fit will be the same no matter what quality of stock you put in it. Cupped stock, stock with snipe, stock of slightly different thickness, nothing will change the fit. The fit is set by matching the bit to the fixture, not by raising or lowering the bit in the router. Add a couple of pieces of t-track and moveable stops and it's set for production. The last great feature (and the best of all), turn it upside down and clamp in the stock. Then run it on your router table. No more balancing the router, no more picking up and setting down the router, no more router vibration in your hands, and all the dust is on the other side of you towards a dust hose. What more can I say, it's fantastic!
Re: Dove tail jig
Fred Davis
>Dick,
I was starting to wonder if I was the only Dave Keller fan here, everything you said is right on.
I went thru his plant in Petaluma , Ca about ten years ago and I have his PRO jig permanently mounted on to two pieces of 4" angle iron and they sure speeded up Kitchen drawers , which was time consuming with a couple of older jigs I had used over the years.
FredD
AKEDA !!
Mark Valsi Pasadena Calif
Re: AKEDA !!
charlie belden
>I'll second the AKEDA recomendation - whole heartedly. And if you want the details go through the stuff that starts with the attached link.
And before someone accuses me of being a shill for AKEDA - I paid the going price for my unit, have NO association with AKEDA or any of its retailers etc. . My money, my opinions - based on info you can verify.
Re: AKEDA !! AMEN!!
Glenn Madsen near San Francisco
>What charlie said...
45 minutes after opening the box, and bolting down the jig, I had a set of variable spaced through dovetails, mallet tight, in oak, in a medium sized storage box.
THE jig to use, if you're not wanting to handcut special joints. As in a kitchen or bath, for example...
all the standard disclaimers, etc...
Re: AKEDA !! AMEN!!
charlie belden
>Regardless of what dovetail jig you go with they all require getting the depth of cut right - for the thickness of the parts you're cutting. And even if they come with a much hoopla'ed setting device (Porter Cable comes to mind). you're parts thickness may vary from board to board, REGARDLESS of what the lumber store or yard says they are.
And if your parts aren't flat, square ended and parallel sided - don't expect nice tight/snug joints, no matter how you cut the dovetails.
