painting cement wall?
Ernie Miller
>I want to paint a cement wall it is in a basement but it does not leak and has a humidifier in it. can I use a laytex paint? I really do not want to use an epoxy, somthing to clean and brighten it up so it looks good. Looking for economy here not somthing to last a life time
Re: painting cement wall?
>I used an exterior latex trim paint (Benjamin Moore Soft Gloss) on my cinderblock walls. It should work for cement or concrete - provided that you do the prep work (muriatic (hydrochloric) acid rinse).
galen V
>Looks like moisture and or past surface prep has left you with a rough looking wall. If moisture is now gone then suggest you power wire brush to be sure you have all the loose paint off and other areas that are not bonded well. Should give a tooth if the older paints are gloss. Meritic acid wash is good but sure needs to be rinsed well and then dry. Latex should work but then always a risk using below grade.
Easy method is to keep the door closed and don't go down there!
Thoroseal
Nat Robison
>I recently painted a basement block wall with latex paint with with good results. This basement has no moisture issues (although I do run a dehumidifier). I used the DRYLOK moisture-proofing paint for the first coat.......not so much that I had to but I wanted to use some up. Anyway, no probs with latex below grade in my house.
Justin Szeliga
>I saw something a few years ago that said Drylock worked better than ThoroSeal, & you don't have to mix it & I don't know about the Drylock but every time I've use ThoroSeal in a closed area, even a foundation excavation, I've got the runs. Something in the Acryl-60 admix smells like ammonia as it is applied & it isn't good for people, in my observation.
Peace
Justin
Pete LaBelle
>Paint bonding is going to depend what was painted on the wall before, and how it is bonding. Latex paints will breath some (use an acrylic latex....stays flexible). If painted with an oil based finish before, it seals the blocks and traps moisure.
Surface prep is always the part nobody wants to deal with, but is critical to the life of the new finish.
