PM2000 Throat plate/Insert
Tony - Memphis
>I was checking and tweaking last night and found a pretty good sized hump in the insert. Also, this thing is rough as a cob. Not exagerating, it looks like they finished it with 60 grit. Any PM2000 owners have a similar plate or is mine unique? Thanks.
Tony
Re: PM2000 Throat plate/Insert
Dan Mitchell
>Haven't noticed a hump in mine, but I replaced it with a phenolic zero clearance insert early on & only use the original for miter cuts. I guess the finish on the original is not all that smooth, but I never really noticed it being an issue, in terms of wood passing over it.
Dan
Tony - Memphis
>Yeah, that's gonna be a priority project - making a zero clearance insert for it. What material did you use? I've just used baltic birch plywood in the past. I'm still trying to decide if I want to drill holes in the saw to mount my Brett Guard. I'm going to try the stock gaurd for a while and see. I really like the Brett Gaurd though.
Tony
Dan Mitchell
>I bought a PM insert at Woodcraft, a bit pricey at ~60 bucks, I was expecting more like $25. I was a little shocked when they rang it up. This insert is fairly large, compared to other saws, and at the time there were no aftermarket ones, which may or may not still be true. Nice & smooth, though. I made my own dado insert out of MDF.
I like the guard on this saw, much nicer than the one on the Unisaw I used to have. I've thought about an overhead guard to improve dust removal, does the Brett do that? Do you ever find it gets in the way?
Tony - Memphis
>My Brett Guard doesn't have dust removal. I've been using it for quite a while and have always been pleased with it. Mine mounts on the left, so it is only good for ripping.
Tony
