Better mitersaw hold-downs?
Ken Platt (Granby, CT)
>Folks -
I have a makita LS 1013 slider, and love it. It's one of those tools that I've really bonded with, use it all the time. But, for small pieces, I have trouble figuring out how to hold them down and against the fence.
Today I was trying to make cuts on a pen blank size piece. The hold down that comes with it can't get low down that close to the fence. I know this is a popular saw; I'm wondering what folks have come up with. In particular, it seems like something to push a narrow workpiece back against the fence to hold it (rather than holding it down) would be very nice. I fiddled around a bit with the various in-line clamps that I have, but either they didn't fit in those holes at the front of the table or didn't have enough travel.
Anyone got a solution, or found an accesory to fit this saw to help hold narrow pieces?
Thanks -
Ken
Whose grip just isn't as strong as it used to be....
Re: Better mitersaw hold-downs?
Ed Mulligan, Cape Cod
>Ken -
For small stock where my fingers are too close to the blade if I hold it with my hand, I use a pencil with the eraser tip against the work, held in my left hand.
Ed
Curly Smith
>Do you have room to build a hold down with one of these installed Magswitch Mag-Jigs?
pecker
>If you have a hole a the front of the table...maybe stick a dowel in it. Drill a hole thru the dowel, for some treaded rod (or long bolt). A couple wing nuts should allow you lock the rod against the workpiece.
You could make this more elaborate, with jig type knobs to tighten it, and a rubber pad at the end of the rod, to give more friction against the workpiece.
My Delta came with this thing...rotate it 90 degrees for the correct view of it.
Chuck in ND
>For small stuff, such as cuting small pieces of dowl, I usually grab the manual miter saw. I've got a old one that has a length stop.
>Thanks folks.
Pecker, that's exactly what I was looking for; I'm surprised Makita doesn't make such a thing. I have a Lee Valley workbench holder like that, only the cylinder doesn't fit.
Ed, that's a good idea, thanks. Unfortunately when I make a cut the workpiece tends to creep a smidge away from the blade unless I get a really good grip on it. I always figured that was inherent in cutting...maybe it's just my saw?
Curly, I had a major "doh!" moment when I read your response, and ran down to try my magnetic TS holder...but the whole table and fence is nonmagnetic. Guess it must be aluminum. Sigh.
Gee, and here I was hoping to be able to stimulate the economy with a purchase...guess I'll have to try to cobble up something from scraps.
I appreciate the responses.
Ken
Stuart Hough
>Ken, I don't have a slider, but have used a simple setup on my Craftsman 12" mitersaw. What I do is to take a scrap 2 x 2 and the horizontal clamp/press that came with the saw. I put another scrap piece, similar in size to my workpiece, on the outer edge of the saw, and then line the cutline on my my workpiece up with the laser. I then clamp the long scrap across both of the smaller pieces with the horizontal clamp, which immobilizes the workpiece and keeps my fingers far away from the sawblade. Forgive the rambling description, it takes way fewer seconds to do it than to read this. Hope it helps.
Orion
>If you haven't already done it, first make and clamp a zero clearance fence and cutting surface with scrap ply or MDF to your saw. Simply tack a 3/4 x 3/4 strip on top of a larger piece that meets your length and width requirements. This takes all of a couple of seconds and also allows you to tack a stop or two down to the suface to hold the piece and if needed repeat several accurate small cuts. I couldn't live without my brad nailer and scrap.
