Sanding grit for painted furniture
Stephen Kirk in Quakertown, PA
>I'm getting ready to paint some poplar for a project. Normally, when staining I sand to between 180 and 220, depending on the wood. For regular latex paint, should I follow the same sanding regimen or can I stop earlier. I am planning on a primer coat followed up by 1 or 2 finish coats (depending on what it takes). I'm not certain if the primer has good adhesion on a smooth sanded surface.
Oddly enough, this is my first piece of painted furniture. I'm finding I like stain and poly better. It's actually easier to apply. At least it seems to me.
Re: Sanding grit for painted furniture
Steve Schoene
>No reason to stop much earlier than about 180 grit, though 150 probably is OK too. I suggest a shellac based primer such as BIN. I'd use 2 coats and sand with about 220. Examine the surface carefully to fill any dings or dents.
As far as the top coat, avoid latex paint. If you need to use a waterborne paint, make sure it is 100% acyrlic. Go with a top of the line paint, such as Sherwin Williams Pro Classic, or Benjamin Moore Impervo. Oil based enamel still brushes out more easily, and would be more durable over time.
>I've done a fair amount of painted furniture, generally sanding to 150 or 220 with drywall sanding screen. I always use a good latex wall paint in flat or semi gloss, directly on the bare wood. It does not need to go on over any primer. The first coat should be knocked back with the 220 sanding screen, and followed by a couple more coats to get a good even build. After a couple days it's ready for clear top coat if desired. I have topped it with oil poly, water poly, water borne clear epoxy, and solvent lacquer at different times, with absolutely no problems. Although I prefer this base coat clear coat approach, I don't see any issue with eliminating the clear coat if using semi or high gloss.
Here's a piece I recently finished.
Clint
Wow, so you're saying........
Tim Greif - West of Chicago
>Hey Clint. So you're saying you get good results with just about any clear top coat over a normal flat latex wall paint? That's amazing. I would have thought that solvent based stuff or lacquer would have ereacted with the base coat. I gotta try this.
Re: Wow, so you're saying........
>The piece pictured is clear coated with solvent based alkyd lacquer (Sherwin Williams) sprayed on in multiple coats. There may be a softening reaction in the initial spraying, but I don't stick my finger in it to find out, and if so, it doesn't appear to have any negative effect. The resultant finish is certainly as durable as a pigmented oil and looks as good or better.
Clint
>Thanks. I'll try your recommendations on some scrap pieces. I've found that with the primer it doesn't brush out well. I could probably use some better brushes, too.
