>My Freud Panel bit set came with a mini CD that had a pretty good getting started video on it. I watched the video and then made a few sample/practice cuts etc. The instruction sheet that came with the bits had decent info on calculating the sizes of the panels/rails and styles too.
Remember, calculate the size, write it down, cut the panel to size, read the size you wrote down, cut another panel, check the size, and then, read the size, set up to cut the panel, re-read the size, check the setup, then the panel. Third times a Charm:) ......
The video CD that Bob mentioned is included with our 3 Piece Cabinet Door Router Bit Sets. If you will email me with your address I will be happy to send you one.
We must use wood from the same trees. I noticed my panels quickly change sizes if I don't keep watching them. I check them more often than a pitcher checks a base runner. Three times is good. They seem to settle down and behave after that. Good advice.
