PM 2000 Riving Knife
Dwain - Lakeland FL
>Is it a Euro style knife? In the sense that is follows the blade. I've found a couple of posts saying indeed is is but I'm somewhat skeptical because I also referenced the owners manual and there was no indication that it was, so I thought I'd ask.
Also, one of the posts I saw said that there were a variety of riving knives also available aftermarket, but I didn't find any info to back this up on Powermatic's web site so I'm skeptical about this as well. If so where can I purchase them.
can anyone confirm any of this for me. Thanks.
Dwain
Re: PM 2000 Riving Knife
Re: PM 2000 Riving Knife *LINK*
Dan Mitchell
>I have a PM2000. The knife does follow the blade, moving up & down with it & remaining at a fixed distance from the cutting edge at all times.
At least one additional riving knife is available from PM, a low profile one for use when the blade does not penetrate the work. I've considered buying one, looks like you could make it as well with the right gauge steel:
http://www.toolking.com/jet-powermatic_11091787.as
Dwain
>Dan,
Thank you so much for your time. I appreciate it.
Sincerely,
Dwain
Tony - Memphis
>I installed one last night. I bought it at Timberline. It does move up and down with the blade and it is what I consider "European style" in that it is curved to match the blade. One issue I have with it is that I can't see that I can use the blade guard with it. I had considered installing my Brett Guard and this may be a reason too. although, the stock splitter/guard looks pretty good. I'll just have to use them for a while and see. Very easy to remove/change, so that's good.
Tony
