220 Outlet Update
220 Outlet Update
220 Outlet Update
Tony - Memphis
>I just met with the Electrician. He is going to swap some full size breakers for 1/2 size and use a 1/2 size 220 breaker. He said he can arrange everything to work that way without any major changes. Another option was to change the guts of my box. I don't forsee any additions in the near future, so I accpeted the rearranging for now. They will come back Friday to do the work. $125 and I'm good to go. Not a bad deal and all is safe, up to code, etc. etc. The wiring I had done thus far was fine and he had no issues with it. He said he had some good stories about woodworkers and thier elcetrical skills! Love to hear some of those. There is a neat area on This Old House' web site about crazy things folks have found. Some are pretty scary!
I think this is what Barry suggested in the first place.
So, if all goes as planned, I should be testing out the new saw thius weekend. It's almost all together. I haven't checked everything yet. Just can't get over how beefy this thing is. Every piece of it weighs a ton. I'll post more later. I have to get back to work so I can pay for all this. Bossman let me work from home this morning to meet the electrical guy. BTW, I'm using Ellendale Electric if anybody in the area needs any electrical work. They seem to be top notch.
Tony
Re: 220 Outlet Update
Fred Davis
>Glad you went that route.
FredD
Re: Not only woodworkers
Larry Clinton At Frankfort (Central)., Indiana
>I did electrical work for over 30 years as part of my side job. I have seen MANY scary things, including one guy who added some outlets using 24 gage telephone wiring. After seeing one outlet wired that way, I crawled out of the crawl space and asked if he had done some wiring himself. He said he had added some outlets. I explained the error of his ways - told him of the danger and refused to do ANY work in the house as I didn't want the liability - not knowing all he had done. I have seen a large deep freeze in an attached outbuilding running on a #18 gage 25' extension cord - That was when I was a voluntary Fireman. (Yeah, it did burn the attached building - we saved the house.) I have seen interior romax (NM) ran overhead to outbuildings, sunlight had caused the sheath and insulation to deteriorate - shorted out and blew fuses when it rained - that's why I was called. In years past (1950's through 1970's) I have seen many houses running electricity from 30 amp 120VAC 2 circuit entrances - with a penny under each of the 30 amp fuses. When you inspected inside these houses, you might find one outlet in a room with several adapters in the (literally un-fused outlet) with 3 to 5 extension cords running to various lights, tv, stereo, fans and even window air conditioners. Often the outlets were very hot to the touch. I couldn't count the times I have found hot/neutrals reversed in outlets and rewired lamps, 14-2 wire hooked to 30 amp fuses / breakers, multiple circuits on one fuse, chopped off ground wires to the ground rod, etc.
