>Thanks for all the help on the Lane cedar chest. It is coming along nicely and I will send a photo out once it is finished. The replacement lock should be here in a few days, very easy. The truth is, this project has inspired me to tackle yet another project. We also recently acquired a toy chest that has been some what neglected and used as a plant stand so it scratched up and has a bad water stain. Pretty sure the polyurethane needs to be sanded down and reapplied. Do I need to remove all of the poly before applying a fresh coat?
>I probably use a chemical stripper and a scraper before I sanded. You run through an awful lot of sand paper otherwise. You also have more of a tendency to blur details with a lot of sanding (at least I do).
>If the topcoat finish is polyurethane, I would suggest you first strip it with a stripper you feel comfortable with. Always remember to use any safety gear required too. The one I use is pretty aggressive and requires the wearing of neoprene gloves I get from Lee Valley.
Polyurethane will not come totally off with only one application of stripper. You may find it will take two or three goes at it before it's all off. After removing the old finish, sand the wood surfaces, and apply the finish of your choice.
You'll eat up nothing but time and sandpaper trying to sand the poly off. Removing it by stripping will yield a better finish in the end.
>In addition to Davids suggestion on stripper , you will get a much better result from the first application of stripper if you cover it with a piece of Saran wrap or similar material, this cuts down the evaporation rate and improves the action of the stripper.
>If this is a commercially made piece then it almost certain does not have a polyurethane varnish on it. If more than several years old, it is most likely to be a lacquer finish. I'd still use stripper to remove it.
