OT Low e glass
OT Low e glass
OT Low e glass
Sawman
>I had some insulated glass panels made up with low e glass. But I want to be sure that I install them correctly. Is there a way to absolutely make sure that they are oriented correctly? I do not want to rely solely on the stick on label.
Re: OT Low e glass
Re: OT Low e glass
>Here's some really half a$$ed info for you. You can "see" the coating if you hold a candle or a match in front of the panel. In fairly dim light try holding a flame in front of the panel and look through at the reflections. You should be able to see a difference in the surface that is coated and it should be on the inner side of one of the sheets of glass and face outward.
Wish I had a better discription for you, but you should be able to see the difference and at least confirm they got the lables all facing the same way.
Re: OT Low e glass
Re: OT Low e glass
Mark Nowicki
>IIRC, you should see multiple reflections of the flame, not sure if you should see two or three.
Mark
