When do you decide to resaw (and how thick)?
>I went ahead and bought some nice thick cherry. It has been planed down to 2 3/8". That is a little thicker than I need it (needs to be at least 2", but 2 1/8" is also good). Figure on ~ 1/16" for a saw kerf - which would either yield some thick veneer at 1/8" or really thick veneer at 1/4". I can probably go thinner.
My previous forays into resawing have been to get 1/2" slabs. I haven't really been looking to make veneers of any sort (if you can call 1/4" a veneer). So I don't really have any experience in it. I also wouldn't know what to do with it once it was sawed off (in terms of storage). I figure I could make some nice Shaker boxes out of it.
The piece that I'd be resawing would be 4' long, 12" or so wide) and 2 3/8" thick to start. The 4' x 15" piece is beyond the capacity of my bandsaw by a few inches :(.
So - any words of wisdom or directions to nice tutorials (either in print or on the web)?
Re: When do you decide to resaw (and how thick)?
Ray Binnicker
>If you are going to only lose 1/8 to 1/4 inch of material my HO would be to plane your material to desired thickness and forego to re-sawing. Not knowing what kind of bandsaw you have and/or experience you have re-sawing, it would not be worth the risk, or time, taking the chance of messing up the board or damaging a good bandsaw blade.
My 2 cents.
Ray Binnicker
>Good Afternoon JL,
Resaw rather than plane summarizes my philosophy. Thickness is of your own detyermination. To start, go thicker. You'll gain the experience without risk. I always try to resaw down close to my needed thickness, then use the planer to true up the coarse sawn sirface to exact dimension sought. With the falloff veneer, I use an auxiliary veneer table in my DeWalt planer, and pass the veneer thru to desided thickness. I don't think resawing is such a big deal so long as you have an accurate set-up, good fence, blade properly tensioned, good eyes, and take it slow and easy.
As to veneer thickness: 1/4 inch and 3/8 inch is very helpful in doing boxes as you suggested. Also, consider making the furniture backs and drawer compartments from off cut lumber.
Further, resawing will minimize wear on your planer blades while yielding usable veneer which would normally be turned into dust. It also saves time. I do store my offcuts, but never have enough for more than a box or two at a time. It gets used up pretty quickly.
George
Jesse Cloud
>If the board is just thicker than I need it, I'll resaw if its 1/8 too big or bigger, just to save time and planer blade wear.
When I resaw for veneer, I shoot for 3/32 finished, so I saw to about 1/8. 3/32 is thick enough that you can work it and edge glue it, but not thick enough to cause movement worries.
Curly Smith
>First, I'd make sure that my saw is "tuned" then I'd wander over to my lumber pile and select a scrap piece of 2"x12"x4' and I'd practice cutting 1/8" and 1/16" slices. If it's been a long time since you've done any resawing then you might want to start with a 2"x4" and work your way up. As a bonus, think of all those "bandsawn boxes" that you'll be able to build.
Re: Thanks for the advice. I'll do a practice...
>cut (or cuts) on some scrap - after I put in a new blade and tune it.
>This is an interesting thread. By re sawing the wood you are risking the thick expensive blank. (You could screw it up by having your BS blade decide to wander off or "Barrel" inside the piece. And, by taking wood off one side of the blank, you tend to increase the chance it will warp.
What do you get from this? Some thin pieces of wood you might find useful.
Why would you do it? To be frugal. Only if it does not ruin the larger blank.
You save wear on planer knives. I have a lunch box planer with knives I can sharpen myself. Been trading the two sets of knives I have back and forth for about six or eight years. These knives cost about forty bucks a set. I buy bandsaw blades and they cost about fifteen bucks and last a period of time that could be counted in minutes. I just received some oak for a friend. Typical of my resawing. I tried it with the blade that was on the machine. Nope, too dull. OK for thin stuff, but not so good for resawing. Switch to a new blade. Did the resaw. Now I'm too lazy to put the dull blade back on the saw, so the new blade will get dull before the next resaw project comes along.
What I would really like to have is a band saw set up for resawing that stayed set up that way. With a carbide tipped blade. Then I might take a tin slice off both sides of the blank to balance the stresses and plane the rest.
Just not sure that using up a fifteen dollar bandsaw blade equates to minor wear on planer knives. Maybe it would if I were using disposable knives on the planer, or is the blank were spectacular.
Ray Binnicker
>My point exactly (above). Someone mentioned practicing on a piece of 2"x12"x4' scrap. I don't have any scrap that size. I just don't see the advantage of re-sawing in this situation. If I were going to book-match the material; different story. In this case, the board goes in the planer (maby two or three passes) and it's done.
Me 2cents.
Ray Binnicker
>The larger piece (~15" x 4' x 2 3/8") - I don't have the capacity to resaw this piece. As a matter of fact, I have to take it over to Mike's shop to plane it (he's got a 15" planer). The other piece is currently ~15" wide, but I was going to rip it to get a knot out.
I suppose I could plane both. I don't really need a thick veneer, I do need the 2" + blank. I was just wanting to have my cake and eat it, I suppose. But I can think of a few projects where a thick veneer might come in handy. Primarily Shaker boxes.
