Sliding Dovetails on a PC 4212
A300 Pilot
>I've had a Porter-Cable 4212 dovetail jig for some time and just started to use it for some sliding dovetails and ran into a problem with cutting the tenon board. I followed all the steps in the instruction book but knew as soon as I took the board out on the jig that the fit was wrong. The instructions say nothing on how to setup the jig so the cuts get you close to a good fit. They also don't say how to keep the tenon centered on the board. Is it all trial and error or is there something I'm missing?
Re: Sliding Dovetails on a PC 4212
>What seems to be the problem?
Is the depth okay? Usually if you lock your router in that position, it stays put.
Are the tenons loose or tight? I usually try it with a piece of scrap that is the same thickness as my tenon board. I do the climb cut, then the forward cut. I then rotate the board and climb cut and forward cut again.
A300 Pilot
>My question is: Is it trail and error on your scrap piece to size the width of the tenon, or is there a technique that I don't know? The depth is OK i.e. same as your dado cut.
>Pretty much trial and error. There definitely is no magic technique.
That's why I usually start with a piece of scrap. I start with tight fitting joints and shave off a little bit from each side (less than 1/32").
Ken Garlock, Collin County Texas
>Here is an idea I saw in a demo video for an Incra router fence.
First thing is set the dovetail jib to the side.
At your router table, set up your dovetail bit so that it cuts exactly 1/2 its diameter. Run your tenon board through on each side, and viola(a large violin) you have your dovetail tenon.
Step two: take your router and lift assembly out of the table and take it to your mortise piece. Do Not change your depth of cut. Turn the router/lift over with the bit pointing down. Align the bit center with the center line of the mortise. Place a straight edge along the board as a reference for the router, and cut the mortise. IF the dovetail is wider than the diameter of the bit, then you will need to shift your starting line and make two passes through the mortise to get the correct width.
Hope this makes sense,
Ken
