Floor Sanding- ARGGH!
Dean Lapinel
>1500 sf red oak with previous 15 y.o Street shoe finish (water poly).
Using U-sand (4X 6" discs.
Finish is 98% off now but odd things happening.
kingspor discs
Norton discs
Both do the same;
At 36 grit they skip and really don't remove anything and don't wear down (machine is 150 pounds).
60 grit removes wood for about 15 minutes.
I need to sand down into those little shallow grain lines that can't be more than a mm or two deep. The old finish remains in these areas. It would take too many passes with 60 to get the whole area done....SO SLOW!
Any ideas about why the more aggressive grits aren't "catching"?
Wet the floor first?
drum sander is out of the question due to board layout and space.
