jointer safety, shorter pieces
>What length of wood is too short to be jointed safely? Are there other factors besides length?
Re: My personal preference...
>is long enough to adequately bridge the gap between the infeed and outfeed tables plus a couple of inches. I don't think I'd do anything smaller than 5-6".
Re: jointer safety, shorter pieces
Virgil Johnson, Versailles KY
>I do not like to joint pieces shorter than 8". I can't plane anything shorter either. That is the distance between the infeed and outfeed rollers on my planer.
>Long before I knew him, my high school principal was a shop teacher. H demonstrated to the class why it was dangerous to joint short pieces and in doing it, jointed off the tip of his little finger. I wasn't there, but I bet know one who was ever joints any short stuff and maybe never joints anything at all. No wonder he moved into administration. At that rate his career would have been over in ten years.
I limit myself most of the time to about 12" but might sneak down to about ten. Not much thinner than a half. Probably don't get as much out of the jointer as I could.
>I stupidly tried to pass a 6 inch piece over the knives and trimmed the tips of the first three fingers of my left hand instead. Not a pleasant experience.
Joe Dusel (Vista, CA)
>First off, I would NEVER run wood less than 12" through a jointer. As my teacher taught us, your hands should never be closer than 6" to the cutterhead. You really need to either do some hand planing, or use a sander for really small stuff. And if you are using an American style jointer with a swing guard you really need to be using push blocks anytime you are passing over the cutterhead. The Euro machines with the fixed guards are much safer, assuming you use the guard.
This past Spring one of the instructors at our community college was jointing a small piece of wood on a 6" jointer. The wood kicked back with his hand over the cutterhead. He removed 3 1/2 fingers from his left hand. This sent him and most of the woodworking students and instructors into shock.
Joe
Jesse Cloud
>At school, they teach us 12 inches, which feels about right. Anything smaller I would use hand tools to face joint and maybe a router to edge joint.
thanks
>Thanks for the replies. I wanted to joint some turning blocks about 6-8" square and 8-12" long. This was mostly to show the figure on some pieces we want to auction. I've done some of the longer blocks.
I also did some internet research and read the horror stories. It seems most short board accidents occur when the supporting left hand is over the cutting head when the board, usually a thin board, gets caught, kicks back, breaks, or otherwise disappears. Since the left hand is pushing down directly into the rotating knives at that point, when the board is gone the fingers go right into the knives.
One piece of advice seems to be universal - never get into a situation where either hand is directly over the cutting edges. One suggesting always asking yourself the question, where would my fingers go if the wood suddenly disappeared?
I wonder when SawStop will come out with their JointerStop and ShaperStop models.
Pete in Holland, MI
>I have a little jig that looks like a hand plane, about 3" wide and 16" long with a small lip on the trailing edge, and fine sand paper affixed to the bottom that I use to joint small flat pieces thru my jointer. Allows adequate pressure to the board and keeps my fingers away from the blades. Yes, there is a minimum of wood that needs to contact the bed, else it'll tip into the gap.
All slots are not equal, SO a factor might
Keith Newton, LR, Arkansas------WebKitFormBoundary
>make more sense. My 12" jointer has a slot 2.25" wide, and my Makita 6" powerplane has a 1.25" slot. If I chose a rule of nothing shorter than four times the slot, it would be 9" for the large one, and 5" for the other if I had the Makita mounted in the vise, and was using it as a stationary jointer.
Of course, if I wanted to go smaller, I could clamp the wood, and run the powerplane over something down around 3" without any worry.
I have on more than one occasion recommended this tool as a good alternative to those who are working in a small space, over getting a stationary jointer which eats a lot of floor space when it is not in use. This usually lives under one of my benches.
