I need a really aggressive drill Bit......
>I have been working on a house for my cousin and we are about to re-wire it. I need a bit to drill holes in the studs for the wires. Those studs are sixty year old yellow pine and about as hard as Woodpecker's lips. I want the holes to be about 1" or 1 1/4". The holes don't have to be pretty. If they made tiny little shaped charges or hand grenades, it would be fine. Any suggestions?
Re: I need a really aggressive drill Bit......
Glenn Madsen in the SF Bay Area
>I went to the local supply house/hardware store, and talked to the owner/operator. I got a couple of electrician's bits, in 3/4", I think. One was about 20" long, and rigid, a spade bit type of thing. The other was a flexible (bendable) shafted, spiral headed type of device about 42" or so long. And these help drill through most of the post WW2 construction we have in my California county.
But go talk to your guy. Find the smart one who knows what this is all about. You're not the only one needs to do this stuff.
By the way, if you can keep your kids from keeping these, they last forever. If the boys don't return them, then not so long. DAMHIKT
Ray Binnicker
>Barry,
Look at the Irwin "speedbore" bits. My son-in-law used them when he was wiring my shop and I tried to help using a 1/2" drill motor and learned real quick to make sure I had a man-size grip when I mashed the trigger ! They don't make a clean hole, but they make a hole in a hurry.
Ray
Howard Norman
>I like the Milwaukee Selfeed bits myself. They come in various lengths and you can get Milwaukee extensions for them also. I have never used them on old lumber like you are talking about but on new studs they seem to be the best that I have found.
JoeW in Detroit, MI
>Ship's auger, self-feed, or whatever else they may be called. Don't cheat on the size either, you may have to pull more than one circuit through the hole. Bigger is better.
Greenlee Nail Eater®
Rod Peterson -- Ormond Beach
>I tried the Milwaukee self feeds and they puked every time I hit a nail. The eponymous Greenlee's go through them like buttah. You'll need a torquey, relatively low speed drill, and be sure to brace yourself, because they won't stop turning when the going gets tough—you'll want to be well braced when the previously mentioned torquey drill kicks in. ¾" is a good size.
Rod
Fred Davis
>Electricians bits do fine as any electrician will tell.
Don't get carried away by thinking the bigger the hole the more wire you can pull though it.
Any building code subscribing to the NEC limits the number of cables that can go in one hole
3/4" to 7/8ths is about it for hole size.
The pro Electricians and Plumbers use a Milwaukee "Hole Hawg drill"
It is a two speed right angle monster that fits between studs, you can rent one if your buddy doesn't have one .
If you use the "Hole Hawg" by all means use the high speed setting , if you use the low speed which is also a low gear ratio , it will wind you up and break your wrists if you get into tough going.
Electricians bits are self fed "ship fitters bits" about 18 " long for overhead boring with a ladder.
Plumbers use a short Milwaukee "machine spur bit" that has teeth along the rim and replacement worm for the spur that you can buy in a slow , meduim or fast thread pitch. Go for the Electrician bit.
Spade bits while cheap and fast give a hole that screams amateur in it's roughness. The neater the installation looks also makes a inspector easy to get along with.
FredD
Mike Fitterling
>I found the Speedbore bits TOO aggressive. I used one while wiring the addition and I don't know how many times the thing almost broke my wrist or got stuck in the wood (soft 2x6 Borg material). I finally got tired of trying to get it unstuck from holes and switched to a regular flat bit. I got to say, though, if you didn't get hung up, that thing would put a hole thorugh a 2x instantly.
Thanks guys......
>I have found that Lowes has the Greenleigh bits and will use one of those for the wiring.
They also have the Irwin three fluted Speed Bore bits. I may try the 1 1/4"one to drill hundreds of holes in the soffit for ventilation. Those holes will be covered by vents/screening.
Thanks again.
