How to bend facia board
Lyle Morse
>The house is a 1903 Edwardian structure. While having a new roof put on, the contractor told me we had to replace some of the facia board and molding. The problem is that as the side facia board nears the front it has an upward curve to it. My contractor tried to bend the facia board but it kept spliting. He said he found a place that could do it for about $10,000......for 25 to 30 feet of facia board that seems excessively high. Can anyone tell me how to bend facia board and molding or where to get it done at a reasonable price?
Napa, CA
Re: How to bend facia board
How much bend are you talking about.
Keith Newton, LR, Arkansas------WebKitFormBoundary
>If it is just a little, I would start with a wide board, and saw the curve starting off on one side, and bending up to the other.
If it is more than can be done from one board, then you should be able to splice wider boards end to end, to get the curve. But you can not really bend boards across the wide axis, it will always flip to the thin plane to bend.
Was there some sort of crown pattern that needed to bend also? Can you post photos?
Without seeing what you have described, I would happily do it for half that, although I am sure you can beat my offer. Ha. k
russastrid
>can you cut kerfs every inch on the inside bend? just a thought, don't know if it will work
Definitions
>Hi Lyle,
To me, a fascia board is a board oriented on edge and applied vertically to an eave or gable. If that's what you mean, it stands to reason that you can't bend it. You will have to laminate it.
If it is a soffit, you could kerf-bend it as someone suggested, or make it out of bender board (a type of flexible plywood). I assume that you will be painting it, no matter what.
More detail will get you a better answer.
Welcome,
Ellis Walentine, Host
Re: Definitions
Glenn Madsen in the SF Bay Area
>So might a picture...
Re: Definitions
Fred Davis
FredD
