Waste not, want not.....
Bill Tindall, E.TN
>I have been accused of being cheap but I consider frugal a more apt assessment. What you are looking at is the bottom of the chest(trunk) I am building. The plywood bottom fits into a rabbit on the trunk bottom....almost.
I wanted an oak bottom and thought it needed to be plywood so it could be fit tight and not expand. I didn't have any. A friend had a cut-off some bigger than what I needed. He also drives vintage Proche that is not ideal for hauling plywood sheets. So he volunteered to cut his piece to the size I needed and he would bring it to town where I was to meet him. When I got it home I discovered 27 1/2" had become 24 1/2" somewhere between the email and the saw.
I had a scrap of oak that apparently I had used for backing on the drill press, hence the random holes in the bottom. It was just a tad bigger than required to "stretch" the plywood an additional 3". I cut a slot for a spline in the plywood and the solid oak piece and carefully glued them together with the solid piece just a bit proud of the plywood. The solid piece was hand planned and scraped to the thickness of the plywood and the joint was satisfying.
The solid part will be under a till in the trunk and not be readily seen. The different colors of the plywood-oak and the solid oak will bleach and oxidize to become similar.
I still need to mount the domed lid, turn some bun feet and mount the hinge.
