>Hey, guys, does anyone know where there might be an idea to convert a self-drive 21" lawn mower so I can have a seat and still have it do the work needed? My hips are giving me H*** and it takes me about 2hrs to do about 4500sgft of lawn.
I do have a mig welder and know how to weld. Just would like to find some one that has already come up with a good idea.
>I don't think a self propelled "push" mower will have: a)the strength in the propelling mechanism to pull you or allow you to ride. 2) even if the transmission would hold up, your lawnmower is too light to have adequate traction to pull you along on a secondary cart, 3) You'll have a lot of time involved in making it so you can ride along with it, and still have a vehicle taxed to its limits, thus premature failure is a real probability, 4) Your little 3-5 hp engine will be too small to move you, and cut grass at the same time. Better start looking at a "real" rider.
>I have an old Gravely two-wheel garden tractor with a front-mounted 40-inch mower deck that's designed with handlebars for walking behind/steering. I have a riding sulky attached. The tractor is 8 hp and heavy enough to pull the loaded sulky up and down mild grades without losing traction. But any kind of steepness results in wheel spin unless I get off and walk beside the rig. Gravely makes (or used to anyway) a dual wheel set for the sulky for going across sidehills. I have to get off or it'll tip onto its side because I have just the single wheels. I can't imagine a common self-powered walk behind mower would be able to do what the garden tractor does.
>I agree with Pete, I can't imagine the engine and drive system would have enough power. I mow with two zero-turn mowers, one with a diesel engine, but even the smaller one has an 18 hp engine and even it doesn't have nearly the traction and "go" as the diesel. Both use quite wide tires on the powered wheels to provide the needed traction.
You might want to try one - the seats are REAL comfortable and you can stretch your legs out in front. BTW, these things are a dream to use. I mow several acres if I count around the fields, and it is very quick. (They cut 52" and 60".) Even when I mow several acres of horse pasture it takes me less than two hours.
Do you have a 4-wheeler? Another option is a finish mower you pull along behind. That would be difficult to mow in tight spots, though.
The picture is of my big mower. The smaller one is more maneuverable and was a lot cheaper but is a little slower to use.
>Thank you, guys, for your responses. I am going to look into buying a John Deere mower or some sort of compatible unit. I agree that the present one is underpowered to do the job.
>If your machine is one with tires about the size of car or standard pickup tires, you could add water to them for more traction if you haven't already.
Just pickup an attachment at a farm tractor dealer (or farm supply store) for your garden hose. Let the air out of the tires and add water. If you're in an area where it gets below freezing and you want to use it in winter, get a gallon of "tractor tire antifreeze" for each of the tires.
>Water in tires? That's ridiculous. Wasn't there a thread here a few months ago about Nitrogen in tires?
Now we're talking about water in tires? That's absolutely ridiculous. Next thing we know somebody will be talking about putting water in the beds that we sleep in.
>Water in farm tractor tires happens all the time , just like a poster said.
For my self I got tired of flat tires resulting from the previous owners penchant for throwing sharp iron like roofing nails anyhwere on the property, even had a Case Tractor wheel weight hit the post hole auger when the corrals were built.
So I had Dons Tires in Abilene fill my John Deere riding mowers tires with foam and also my Bobcat skid loader, that ended the flat tire saga.
Now my mower rides like a lumber wagon because the give in the tires got up and left.
>Well silly me, there I go assuming again, I watched Wayne Lowery (a farmer buddy I grew up with) connect a water hose from his well to the tractor rear tires, so you can see how I was mislead by thinking it was water.
>I believe Mark knows that, he was just making fun of the earlier thread on nitrogen in tires;-) In most cases, it is not just plain water in the farm tractor tires. There are additives in the fluid, but I am not sure what they are.
>Sorry Fred, I did some brief checking about the subject on the web and found that people use water with anti-freeze, or Cloride, or windshield washer fluid, and get a load of the latest, BEET JUICE !
Both my tractor dealer and the old guy down the hill who works on tractor tires both told me that calcium chloride has fallen out of favor due to its corrosiveness. The old guy said he's seen wheels badly corroded. It is still used, but requires special care. For my tractor I had an antifreeze mixture added (an alcohol/water mixture I think) which is not corrosive although it doesn't weigh quite as much.
BTW, on I also thought Mark was joking. At the nitrogen reference I couldn't believe anyone was so ignorant but when I got to the waterbed comment I realized he was tonguing his cheek.
BTW2, for some excitement one day, I knocked off the valve stem of one tractor tire with a stick while clearing some brush. Man, the tremendous sound of liquid exiting at high pressure was startling, to say the least. After I figured out what had happened I drove the tractor up the hill to a flat spot at the house, parked with the valve stem up, got some blocks and lifted the tire off the ground up with a hydraulic jack. Even with all that, when the valve stem was replaced the tire hadn't lost enough liquid to require adding any. The volume in those tires is huge! For even more fun, try to load a huge tire full of liquid into a pickup truck to take to the tire shop!
BTW3, Calcium chloride is great for preventing those dark spots on the bottom of some tomatoes, caused by a calcium deficiency. You can buy 10 cents worth at the farm store for about $15 and spray it on the tomatoes.
