>I know that type of intro will bring out the pundits but I'm seeking a supplier of what is sometimes referred to as dowel nuts or barrel nuts like the nut used on a Lee Valley bench bolt. We had a local business that sold these nuts but they are out of business and when I contacted a national supplier, they wanted to sell in quantity only (like a minimal order of 10,000 or so which is just a few more than I need). The old local guy had them in bags of 10 or 12 in various sizes. Local hardware stores (and we have a couple of good ones) act like they never heard of such a product and the big box places might have this but only in 1/4" and no other size if that. Appreciate any help...thanks.
>I think all the major mail order suppliers carry them. Lee Valley has them in 10mm diameter, as I recall, and Woodcraft has them for 1/4-20 bolts. Both are major sponsors of WoodCentral. I'm pretty sure Rockler has them too, and they are also advertisers.
There is also the custom option. Whenever I built a bed, I would always connect the rails to the posts with stub tenons and barrel nuts and 3/8"x 5" socket-head cap bolts. I could never find barrel nuts exactly the size I wanted -- 1" in diameter by about 3/4" so I'd get the local machine shop to make them up for me. They ended up being very affordable.
>I usually make my own. I get the appropiate size piece of cold rolled from one of the big box stores. I make a 45 degree cradle to hold it on the drill press, center and drill with the right size tap drill and then tap. I saw a screwdriver slot on the end with a hack saw. The hardest thing to do is cutting the bar stock to length. Make sure you have a good hack saw blade.
>I'm not exactly sure what a barrel nut is as I found several different descriptions, but if you Google Barrel nuts you will find them in 100 unit bags at Amazon.
>I made mine too. I bought a 3/4 cold rolled rod att he big box and cut it into 2" pieces with a metal cutting blade in a Sawzall. Drilled a 5/16" hole through them and threaded it with a 3/8" tap. These were the type where the hole goes through the side, not the end of the piece.
My metal working skills are not the best so I made about six to get four better ones. I drilled the holes for the slightly over sized and then made a jig that allowed me to epoxy them into place. I installed them in the bed posts and used a short "dummy" rail to run the bolts through. (In my case, I want nothing to show, so I ran the bolts in from the rails not through the posts.) So, I put a barrel bolts loosely into each leg, bedded in epoxy and ran in the bolts. When the epoxy hardened it served two purposes, the barrel nuts are anchored in perfect position and it spreads the load out to the wood a bit. I carefully greased the threads in the barrel nuts and on the bolts to avoid gluing the bolts in the holes. The bolt holes were slightly over sized also.
They worked great. That bed is as solid as if it were made of a single piece of wood.
I would think any metal shop could make these up for you and do it better than I did, pretty reasonably.
I wish I had known about the cap screws Ellis mentioned. I made a slot big enough to turn a regular wrench. I also made a slot in the rail of the bed with some magnets in it and put a wrench there for future use. Although the bolts were captive, I made a removable piece that allows for them to be replaced if damaged. There is a magnet that keeps them retracted during storage and shipping.
